Old Part# - 04671594AD (2001 PT)
New Part# - 05073049AB (dated 6/2/07) Cost to purchase at dealer - $63.45 plus tax Install time - 30 minutes or less Tools: Phillips screwdriver, small flat screwdriver, T10 torx Remove negative battery cable Move steering column to lowest tilt setting Remove (2) phillips screws from underside of covering Remove covering top and bottom and set aside Remove (2) phillips screws on top inside Remove (2) torx screws on right side Pull wiper switch section out of your way to the right Take small flat screwwdriver and pry out red locking tab on wiring harness Pull out harness Pull out old multifunction switch Transfer foam dust circle to new switch (over lever) Transfer flasher module (not included with new part) Place multifunction switch back onto column Install wiper section with the (2) small torx that were removed Install (2) upper phillips screws Install upper and lower plastic Install (2) lower phillips screws Connect battery and test. Relatively simple install. Small red lock tab on harness is the most challenging part as the harness is in an awkward position. Nice to have headlights back or to be able to turn off your fog lamps. Happy PT motoring KG in Michigan |
Thanks for the Step-by-Step KG. I'm sure it will come in helpful for some owners that have yet to have their's burn up.
![]() ...just CREWZIN along! ® . . . PT Cruiser Links Moderator ![]() 2000 PT. 100,000 miles, Original Owner Visit My Home Page www.CREWZIN.com |
I have a 2003 LTD and am getting the damn fog lamps coming on thing! Draining the battery. Are we SURE it's the multifunction switch? Anyone know the 2003 part # on this? Danka
![]() Also, does it help to unplug the lamps? or is it something else? Last edited by cocojaja; 05 Sep 2007 at 08:35 pm. |
If you don't want to replace the multifunction switch right now, take out the 15amp fuse #8 from the fuse box inside the car by your left knee. You won't have fog lights but they won't be draining your battery down anymore either.
Thanks!
| Multifunction switch | gonzomania | General PT Cruiser Discussions | 14 | 03 Sep 2009 09:00 pm |
| Error Codes | skylight | Tech & Performance Forum | 6 | 07 Apr 2007 02:19 pm |
| MultiFunction Switch Issues-HELP !!! | jmack | General PT Cruiser Discussions | 9 | 21 Feb 2005 12:52 pm |
| Multifunction switch for postage | Shini Quiet | Classifieds: For Sale/Trade | 0 | 23 Sep 2004 10:29 am |
| Multifunction switch | gonzomania | General PT Cruiser Discussions | 5 | 23 Feb 2004 05:35 pm |
