Heat/air blower moter
Old 03 Jul 2007, 07:10 pm
Default Heat/air blower moter
hearing a "clicking sound when fan is turned on with air. looked for blower motor in firewall but didn't see it?
Old 03 Jul 2007, 10:02 pm
infernocruisr01's Avatar
Send a message via AIM to infernocruisr01
Default Re: Heat/air blower moter
Remove the lower dash panel from the right side of the dashboard below the glove box. Pull back the carpet and disconnect the blower motor electrical connector. Remove the blower motor mounting screws then remove the blower motor. Good luck.
Old 04 Jul 2007, 11:04 am
Exclamation Re: Heat/air blower moter
If you find leaves and other debris when you get the blower motor out, you may want to install a cabin air filter up under the windshield cowling.
John & Terry
"His" - 2002 Inferno Red Touring Edition
"Hers" - 2003 Electric Blue Limited Edition
Del Val PT Cruisers
Old 27 Jul 2007, 07:07 pm
noise has stopped but think i might pull it and check it before the snow starts flying.
