Crazy door locks
Old 08 Jul 2007, 08:46 pm
Default Crazy door locks
Has anyone had an issue with the door locks having a mind all there own? I can go out to the car and all of a sudden they will just start locking and unlocking for a few times. I have no idea if it happens when no one is around.
Thanks in advance for any help
Joe
Old 08 Jul 2007, 09:20 pm
Default Re: Crazy door locks
I did a few years ago. It's a very common problem that the dealer took care of by replacing a defective lock switch in the door.
when all is said and done..
more is usually said than done!
Old 09 Jul 2007, 08:20 am
To keep my costs down I'll probably have to change this out myself, do you happen to know if it was one particular switch or can it be any of the switches could make it happen?
Thanks for the information
joe
Old 09 Jul 2007, 11:23 am
Try changing the battery in your remote. A low battery can cause the remote to do crazy things. Go near the car with and without the remote to see if thats what's causing your problem. If not its the notorious activators. Don't know if you can disconnect one at a time to see what one is noisy and causing problems.
Old 09 Jul 2007, 04:46 pm
I've changed out the remote batteries, no go. It will do it when the remote is not near the car.
I haven't bought a manual yet, so are the activators the same as the door lock switches?
joe
Old 09 Jul 2007, 07:43 pm
You also might be having trouble with your RKE. It's located in the center of the dash above the air vents. I've heard of that piece going bad and making things activate by themselves.
Old 09 Jul 2007, 08:43 pm
soonercruiser's Avatar
Wink Re: Crazy door locks
We're not takin' about when your keys are in your pocket, are we??
I'm walking out into the garage, or just sitting at the table and my horn goes off or something - doors locked of course!!
Wife getting so used to it that today at the dinner table - Wife says..."Was that a fart"??
Gotta love her sense of humor!
Old 09 Jul 2007, 09:24 pm
Default Finally Found the Receipt!
After some searching thru my files I found the invoice for the "crazy door locks". I had this fixed on my 2003 PT in Jan 0f 2004. I haven't had the problem since they fixed it.
The invoice says:
Perform DRBIII Check fault code found drive door switch failure. Perform ohms test from drive door lock cylinder switch to RKE module. Found lock cylinder switch short out.
Old 10 Jul 2007, 08:44 pm
Sounds like she's kinda usta it sooner ,
Nope, not in my pocket. It happens when the keys are still in the house.
Ok, I've got two options now (besides the RKE module), 1 is to just buy the door switch or 2 to buy a manual from HELM inc. (if they have it) and see what the ohms are supposed to be, and it would also tell me if it is the RKE.
I'll look it up and see if they have one first.
joe
Old 11 Jul 2007, 09:33 am
Mine had the same thing happen and it turned out to be moisture in one of the door lock silinoid...replaced and no problems since.
This was after they removed the interior of the car to get at the rke.
Crazy missfire ! ptTurbo528 Tech & Performance Forum 5 28 Mar 2006 11:43 pm
Super Cruiser (Crazy Idea?) PT-ERA General PT Cruiser Discussions 33 18 Feb 2005 07:17 pm
Radio drives me crazy!! Alan Welch Sound and Security Forum 2 03 Feb 2004 01:44 pm
Cold Cold Crazy PianT General PT Cruiser Discussions 13 21 Jan 2004 11:35 pm
This rattle is driving me crazy! HELP! ElectricBlueGT Turbo Wheels/Suspension/Handling 6 19 Dec 2003 10:49 pm
