Crysler called me this am. They want to put a thermostat and new radiator in the car. $720
They say its not getting enough flow. I told them I will call them back. Of course the parts must be ordered and will not be in until monday. So my question is......if it were the radiator why doesn't the car overheat until I actually drive it for awhile? ![]() |
I was just sitting here thinking
The car does not get that warm on the interior when I turn the heat on in the winter. I live in Ohio and it gets pretty cold at times. I had a older car that the heater core went bad, but with that I had a foggy film on my windows. |
"not getting enough flow" ?? water pump ??
If it is being worked on at the same place that did the pressure test, show them the paperwork from that and ask them WHY???
2008 Silver Steel Metallic, Touring, NA, Sirius; chromed door handles; lower grille; fog light surrounds; chrome front & rear bumpers strips; Airaid air filter; Bassani duals; Modesty cover; Autolite AP5263 Platinum Plugs (.040); Crane Plug Wires; NAPA Ceramic pads; Blane hood struts; PTeazer Gas, Brake & Foot Rest Pedals. |
Well, here is were I stand at this time. They want to do the thermostat and radiator: $720. Talked it over they came down to $530. I have no confidence in this shop. I did say why didn't anything show up when you did the cooling system flush and vacuum test? which probably was not done. I called them back friday told then to order parts. As of now I have decided to go pick my car up and try a few simple checks myself, then go to another shop. Can you members please give me some guidance on what to check. Fan just replaced a week ago. It was running when car was in park. Still overheated after drove awhile in start stop traffic. would cool down if car was moving. I also notice the last winter the interior of the car does not get as warm as it did in the past. I copied the diagrahm Cruzin posted of the fuse box under hood. I will check that.....I have removed the fuse under on the inside drivers side that runs the fogs lamps. My multifunction switch went crazy. Could that fuse effect the overheating? Thanks to everyone for your help! ![]() |
How many miles are on the car?? I will play devils advocate here. Almost all engines today are iron blocks with aluminum heads. This tends to create a problem when they get many miles on them. Your problem sounds very similar to what I had happen last week. Close your eyes and cover your ears...Blown head gasket. This happened not on my PT it only has 20K on it but my Chrysler Lebaron with 170K. It would get hot in stop and go and cool back down on the highway although it was running alittle warmer than usual which is what caught my eye. Check your tail pipe for a white misty smoke and moisture coming out of the tail pipe. That is the give away for a blown head gasket. If you can take the thermostat out do that and put the hoses back on. Remove the radiator cap and start the engine if the coolant in the radiator is bubbling like a pot on the stove it is definetly a head gasket. My engine is currently torn down to the block and waiting a new set of heads. If it is a head gasket that is blown you will need to get the head resurfaced because the aluminum heads tend warp which is what causes the gasket to blow. If you keep driving it and letting it get hot it will eventually crack the head and then you will be replacing the head. I certainly hope that a radiator flush works for you or as mentioned earlier maybe the water pump but that will usually make it run hot and overtemp all the time cause there will be no water flow at all. Good luck and keep us informed and I hope I am wrong....this is not cheap. Now if your car is low mileage car then I should be wrong.
Clay
05 PT Non Turbo Dark Plum, Crane Firewires, Bosch Platinum 4's and K&N Drop in. 72 Plymouth Satellite Sebring Plus, Street/Strip. 64 Chrysler New Yorker, 54K original Highway |
86,000 is in my opinion should not have a Head Gasket problem. That doesn't mean its not but with that low of mileage I would definetly look at other items first. Just keep it in mind and if you can at least check the exhaust if its clear and no moisture that would ease my fears.
Clay
| overheating | earle | Tech & Performance Forum | 53 | 04 Aug 2008 02:09 pm |
| 17 x 7 wheels with tires for $550 in NYCity...ASAP | Ctown | Classifieds: For Sale/Trade | 0 | 26 Apr 2006 04:37 pm |
| Is this overheating? | MEXICANPT | Turbo Performance | 6 | 31 May 2004 06:32 pm |
| OVERHEATING!!!!!! | spidy134 | General Turbo Discussions | 12 | 09 Oct 2003 10:35 pm |
| electronic problem ASAP HELP!!! | ptcruzin42 | Tech & Performance Forum | 7 | 19 Apr 2003 07:37 pm |
