Changing the battery
  #11 (permalink)
Old 31 Jul 2007, 06:22 am
Default Re: Changing the battery
Originally Posted by CREWZIN View Post
No. It's located in the front of the engine compartment on the drivers side. If you read my post above, there are about 4 easy steps to get at the battery. Un-clip and take out the front part of the air box. You can then see the battery, and if I remember right (it's been years) there a heat blanket around the battery held on with a strap. Take the strap and heat blanket off. Then the hold down for the battery and the positive and negative cables come off.
Thanks for clearing that up! I feel better about it now because I was dreading having to do what I did for my son's Stratus. Would you believe I am still on the original factory battery for a 2001?
  #12 (permalink)
Old 31 Jul 2007, 07:43 am
The bar/strap goes between the battery fill holes, Right? If as you say it is a No maintaince battery, there should be caps that unscrew or a cover that covers 3 of the cells, either way just remove the cover for the cells by pulling up on one end, GENTLY!!!
Welcome to the Forum and do not shout by using all capitals.
  #13 (permalink)
Old 05 Aug 2007, 12:31 pm
jazzmaster43's Avatar
Default Re: CHECKING BATTERY
In this situation of a battery install at say auto zone or advance..you would also have to take off the bar before they would continue with a Free Install..those are but a few of the times those 2 companys will ask you to do something for there Free Time, No Cost battery installs...
JazzMaster43
  #14 (permalink)
Old 19 Dec 2007, 03:25 pm
KIMS CRUZER's Avatar
I just called autozone to get a battery. I was told " I believe thats one of the cars where you have to get up through the wheel well." He then said the PT is one they don't install for that reason. I'm reading the wheel does not have to come off?
  #15 (permalink)
Old 20 Dec 2007, 11:35 pm
Taggert_LOA's Avatar
Send a message via AIM to Taggert_LOA
advance autoparts autocraft silver 67.98 with FREE installation. that what i paid for each car.
"Every civilization finds it necessary to negotiate comprimises with it's own Values"
PT Crusier battery dies after 5 days of no use. PT OWNER General Turbo Discussions 22 28 Jan 2009 11:51 am
Possible Battery Problem ? Johns Steel Blue Tech & Performance Forum 2 02 Jul 2007 08:31 am
Battery Corrosion SteelBlueGT General Turbo Discussions 9 19 May 2005 06:47 pm
BATTERY SOURCE NEEDED clevelandmike General PT Cruiser Discussions 3 06 Oct 2004 09:54 am
Volume reduced when battery disconnected tom-t-rifik Sound and Security Forum 0 28 Jun 2004 05:25 pm
