Better MPG for a 2005 Crusier
Old 03 Aug 2007, 09:45 am
Default Better MPG for a 2005 Crusier
I just bought a 2005 PT Crusier and I've been told that I can improve it's gas mileage by putting on a duel exaust and maybe a new (about $50) air filter. Is any of this true? Can someone help me?
Thanks AJ
Old 03 Aug 2007, 10:52 am
infernocruisr01's Avatar
Send a message via AIM to infernocruisr01
Default Re: Better MPG for a 2005 Crusier
The more air you can get in the engine from and aftermarket air filter and the more exhaust gases you can get out from a free flow exhaust will help out alot also think about a header and a free flow catiletiac converter too. Also check your pcv valve ( positive crankcase ventilation) and plugs and wires will do it. I hope this helps.
Welcome to the fourm and enjoy your cruiser!!
Old 03 Aug 2007, 11:26 am
K&N drop in air filter, part # 33-2153. Should be around $30 or so. If you have Autozones in your area they carry it. This is a reuseable filter so don't forget what is called the Recharging kit for $10-15. I haven't checked the mileage interval yet but every so often you have to clean it and re-oil it.
Also, many do what's called the air box modification to improve the airflow even more. I have done it and it is very simple and takes less than an hour even for a novice. It entails removing a white ring silencer and cutting back the snorkel that feeds into the airbox. If interested, you can search on it in the forums for more detailed instruction.
Old 03 Aug 2007, 11:36 am
JC, thanks for the info. I had a guy tell me that if I put on a dual exaust it would help a lot, have you heard of any such thing?
AJ
Old 03 Aug 2007, 11:37 am
Ditto to you too Inferno.
Old 03 Aug 2007, 06:27 pm
soonercruiser's Avatar
Thumbs up Re: Better MPG for a 2005 Crusier
AJ
Most of the "Not it all's" on the other sites say that a dual or unrestricted exhaust is only a benefit to a turbo. i.e., no help to a NT.
The other posts have covered the inexpensive fuel mileage mods.
Old 04 Aug 2007, 01:07 pm
mjb457's Avatar
The duals do nothing for MPG or performance (mainly looks & sound) K & N is great! I had them on for 4years--same MPG--- Hard to help PT non turbo adding any extra pipe & smaller muffler without other upgrades,
Old 04 Aug 2007, 02:17 pm
I posted this before to another owner that was loking for better mieage, maybe it will help here.
The PT isn't known for it's mileage. The faster you go the worse it gets. Aerodynamically it's a brick. Load of little things you can do to increase the mileage. Go about 3-4 pounds of air above the recommended pressure in your tires. Switch to synthetic oil. Take off from stoplights gently and slowly (but not slow enough to piss people off) get up to the speed limit. Don't run up to stoplights, look ahead and take your lead foot off the accelerator when you see a red light coming up. Don't carry loads that you don't need (like golf clubs all week long when you only golf on Sundays). If nobody else gets in your car, take out the back seats. Go on a diet. ...only kidding. Every little bit helps.
Meet Me In St. Louis 2005 - International PT Party Big Kahuna Midwest PT Forum 5 26 Apr 2005 09:03 am
Meet Me In St. Louis 2005 - International PT Party Big Kahuna General PT Cruiser Discussions 5 02 Feb 2005 06:00 pm
New 2005 Convertible PT Dream Cruiser skylight PT Cruiser News and Rumors 4 11 Jan 2005 06:12 pm
2005 GT Convertible - Best Dual Exhaust??? MACE Turbo Performance 20 14 Aug 2004 12:12 am
2005 GT Convertible - Mopar Peformance Parts? MACE Turbo Performance 7 04 Jun 2004 03:59 am
