I have a 2001 PT and the A/C quit blowing cold today. The fan is running but blowing hot air. I don't have a manual and am curious as to where the fuse is and what amp. I don't have a fuse box diagram or know where it's located. Any help is appreciated, it was 100 degrees today and going to stay that way for a few days so I need to get this fixed.
Welcome to the forum.
The A/C fuse is in the engine compartment fuse box. It's the #11 fuse and it's 10amp.
Can anyone tell me what the Fuse in position number 13 on this diagram is, and why it might keep blowing on me?
It's a 20A for the Fuel Pump/Auto Shut Down (ASD). Back to the picture: See Relay #E. That's the ASD Relay. It "COULD" be why your fuse is blowing. Replace it with the relay from #A (Horn Relay) and see if the fuse stops blowing. You won't have a horn while you do this. If it works, buy a new relay for the horn.
Thanks for that crewzin, as it turned out the previous owner has obviously had radiator fan issues. He solved it by connecting the top left pin of the fuel pump relay to the top left pin of the fan relay, thus making the fan come on when the ignition is turned on, but putting to much load on the fuel pump fuse causing it to blow! Crazy!!!
![]() Now i need to try and figure out why the radiator fan isn't coming on and fix it properly! When the temperature gets to about half way on the guage the fan still doen't come on and there are boiling water sounds from behind the dash. I assume the fan should be kicking in before the coolant starts boiling? Last edited by wwelbourn; 11 Jun 2009 at 02:14 pm. |
The fan should kick on low speed as soon as the A/C is turned on and stay on as long as the A/C is working.
It should also come on when the temperature sensor reaches a particular setting. If you can hear water boiling you could have 2 problems. Air in the coolant system (not bled properly) and possibly a burnt out fan motor. The fan motor seems to be a very weak item as myself and hundreds of owners have had to either replace the motor or the whole fan assembly housing w/motor.
Hi Crewzin. Thanks for all your input on the PT Cruiser. I, as many others, is now dealing with the same fan issue. In your post you mention that the low speed fan operation turns on immediately when the A/C is turned on.
Below is a chart in the 2003 PT Cruiser manual (2.4L Engine) ![]() Am I reading the chart incorrectly or is it indicating that only high speed operation turns on with A/C? Thanks. |
OK, I see what the chart says but everything I've ever read and I've proved it with my own car, no matter what the temperature is, if the compressor comes on with either the A/C on or the setting on defrost mode, the fan will come on with the low speed.
Try it yourself please and let me know. First thing in the morning, run the can without the air, look at the fan to see it isn't running and then turn the A/C on to see if the fan starts up. The low speed make very little noise so you have to actually look to see if it's turning.
Crewzin,
I believe I am experiencing issues with the fan therefore my tests would be inconclusive. Currently when the A/C is turned on, I am getting no fan operation whatsoever. When car is idling with A/C on, the A/C will eventually blow warm air , idling hesitates, and the engine compartment jolts aggresively as described by many others. With vehicle in motion, A/C blows cold air fine. Early research led me to believe that the low-speed relay may be at fault. I gambled on swapping the part but it may no difference. As you stated, the root of the problem is rarely the low-speed relay but rather the fan assembly itself. Unfortunately I read your post after I had bought the relay. The chart above further caused more confusion because I interpreted the information to mean no low speed fan operation occurs when the A/C is on. Again I stumbled across this information after I replaced the relay. However, the question remains whether the fan comes on on low-speed with A/C on or not. I will take your word that it does. My next attempt will involve trying to remove the fan assembly and test it on the bench, possibly look at the brush wear on the fan motor. Not sure yet how complicated the fan assembly removal will be. |
Test the motor in a different way. From the back of the motor there's an 8-10 inch cord that goes to the electrical connection. A red tab at the top pushes to the right and then pull the center tab up so the connection comes apart. You can then run a ground and hot wires to the pins inside the part of the connection that goes to the motor. It should run with the wires attached.
I've also placed a "sticky" on the top of the Tech & Performace section that explains how to remove the fan and housing.
![]() ...just CREWZIN along! ® . . . PT Cruiser Links Moderator ![]() 2000 PT. Original Owner, 110,000 miles MY technical suggestions are given in GOOD FAITH without total guarantee, if in doubt go to a Garage. Visit My Home Page www.CREWZIN.com Last edited by CREWZIN; 30 Jun 2009 at 02:19 pm. |
| iPod Interface for 2001 CHRYSLER PT CRUISER | chicagoskiiguy | Classifieds: For Sale/Trade | 0 | 13 Jul 2007 11:02 am |
| Fog Light Fuse | bkarr | Exterior Accessories Forum | 3 | 15 Apr 2007 08:43 am |
| How do i get power to and wire neons from fuse box | CruiserDan | General PT Cruiser Discussions | 14 | 23 Feb 2004 09:05 am |
| Autometer gauges | PTGT Redman | Turbo Performance | 12 | 23 Jul 2003 09:08 am |
| 2001 PT Cruisers | wayne4178 | Interior Accessories Forum | 6 | 20 Jan 2002 09:10 pm |
