Lower dash, glove box and A pillar trim removal
Old 22 Aug 2007, 04:24 pm
Question Lower dash, glove box and A pillar trim removal
Hi.
Can anyone tell me how to remove the glove box from my 2004 Cruiser please?
Also, how does the large panel below the steering wheel come off?
Last one, how can I safely remove the trim on the A pillars?
Thanks in advance
Old 23 Aug 2007, 09:23 pm
Default Re: Lower dash, glove box and A pillar trim removal
Originally Posted by PingSpike View Post
Hi.
Thanks in advance
The glove box hinges at the bottom. Just sort twist each hinge a little and it will come apart. Not hard at all.
Panel below the steering wheel: pull down on it just under the steering column. It is hinged just like the glove box door.
A pillars: pull on the pillar at the top just enough to get to pop out. The bottom slides into little slots into the dash. Just pull toward you and the bottom will slip right out.
Hope this helps. Let me know if you need more help. I can send pictures if needed.
Frank
Old 23 Aug 2007, 10:54 pm
Cheers Frank, I'll give it a go!
