rear hatch unlatching at startup
Old 26 Aug 2007, 03:53 pm
Default rear hatch unlatching at startup
Have been enjoying our 2005 PT for nearly two years now and yesterday discovered that the rear hatch unlatches when we start the car. It only does it after using the remote to open the door and then starting up. If I lock the doors after we get in then no problem. After getting out and closing the rear hatch and starting up again it stays latched.
Old 07 Sep 2007, 11:29 pm
Default Re: rear hatch unlatching at startup
Problem resolved. Problem started getting worse so pulled the fuse to the RKEM and started up the car. After trying to use the power door lock switch and finding it was also part of the RKEM I turned the switch to off and replaced the fuse. Everything is working normally again. Since the RKEM is programmable I think it was corrupted and removing the fuse rebooted it.
Old 13 Sep 2007, 07:19 am
Wow. Thanks for getting back with the resolution. That may save someone else the grief you had.
Pop the rear hatch open using the remote zapwizard Exterior Accessories Forum 4 28 Jun 2007 08:32 pm
Rear Hatch Opener Install ? StevenAndEva Sound and Security Forum 1 24 Feb 2006 12:23 pm
Rear Hatch Open light stay on? KingKole02 Tech & Performance Forum 5 13 Jul 2004 01:25 pm
NEED - Rear hatch...inferno red Cal Cruzer Classifieds: Want To Buy 8 01 Dec 2003 08:22 pm
Handles for Rear Lift Hatch Dundevil Exterior Accessories Forum 6 05 Aug 2003 04:59 pm
