Is This What I Need?
Old 21 Sep 2007, 12:57 pm
Question Is This What I Need?
I will be running 225 40 R 18's with a 35 offset on my 03 PTCruiser Limited and I need to know how to properly adjust the camber so I don't rub my tires prematurely... Is this the kit I need?
Gold-Line PT Cruiser Front and Rear Alignment Kit - AutoTruckToys.com
Thanks
Old 24 Sep 2007, 12:36 pm
Default Re: Is This What I Need?
Is the outside diameter remain the same as stock? There are site where you plug in the tire size & aspect ratio of new and old and it gives you % difference. If you are the same or close, why do you anticipate camber being off? The kits are for when you lower the car - that could upset the geometry, but wheel size - as long as overall size is the same - should not louse up camber.
