'04 PT Turbo/GT stalling problems!
Old 29 Sep 2007, 09:13 pm
Default '04 PT Turbo/GT stalling problems!
Good evening all!
I drove my 04 PT with 42k miles around all day today with no problems. This evening I backed it out of the garage and stepped on the gas and it stalled.
At idle the car sounds great and idles at the normal 1k.
At all times it smells like burning gas coming out the exhaust.
If you give the car half gas (what i would consider normal to start moving) the RPM will go down to 0 and the car will stall
If you give the car a tiny amount of gas the RPM will drop a little and the car will drive forward.
If you continue to only give it light gas you can get the speed up to normal driving speed and you still smell the burning gas.
If you are driving normal speed and press the gas down to accererate at a normal amount you hear some crazy rattling up at the engine. Sounds like rocks in a can.
If you put the car in reverse everything seems perfectly normal.
Temperature is in the normal range.
I did fill up earlier on today, could I have gotten some bad gas? Should i run it till it runs out of gas and try putting new gas in the vehicle or is that a waste of time?
Thanks!
Old 01 Oct 2007, 07:53 am
Default Re: '04 PT Turbo/GT stalling problems!
Welcome.
What you describe is a classic description of pinging or detonation. It is bad for your engine.
Did you put in regular? Try some octane booster if tank is full.
Sounds like you have low-octane gas and the knock sensor is trying to retard spark so much the car stalls.
At 42,000 miles, I hope you have replaced the plugs and wires - if not, that'd contribute to your problems.
Stalling, rough idle, running "hard", hesitation LiLOrion Tech & Performance Forum 36 21 May 2013 12:43 pm
'02 Cruiser with lots of problems :( slpknt2886 Tech & Performance Forum 4 07 Aug 2007 02:17 pm
So much problems before inspection Ctown General PT Cruiser Discussions 3 12 Apr 2005 07:45 pm
Dealer upgrades, any problems??? knowyourturbo Stage Turbo Kits 0 14 Sep 2003 03:21 pm
Problems Oddcouple General PT Cruiser Discussions 1 17 Nov 2002 01:58 pm
