Strut Tower Brace's
Old 29 Oct 2007, 08:45 pm
Question Strut Tower Brace's
Ok guys are Strut Tower Brace's all that. Does it make that much of a diffrance?
You don't appreciate a lot of stuff in school until you get older..... Little things like being spanked every day by a middle-aged woman. Stuff you pay good money for later in life!!!
Old 29 Oct 2007, 09:32 pm
Default Re: Strut Tower Brace's
They are a piece of the suspension puzzle. Strut bar, better shocks, better sway bars (considering from '03 on there isn't a back one), poly bushings, lowering springs or coil overs.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Old 30 Oct 2007, 07:57 am
tpsfoto's Avatar
I just put on a Feedom Design & Yes................it makes a difference!
Off highway curved ramps at 60+ car stays on track.....no more heavy lean....about $125.00 & easy to install.
tpsfoto@gmail.com
2005 Plum Vert GT Turbo HO
Nav, Chrome 17" Wheels 5 Speed
K&N Typhoon Air Intake, AOOgah Horn, Freedom Design Strut Tower Brace
Some chrome here & there....
2009 PT bought with Cash For Clunkers.....sold it for a
2014 Juke
Old 30 Oct 2007, 09:14 am
Another vote endorsing Strut Tower Braces... easy bolt-on improvement to turn-in response.
One bit of installation advice: Strut nuts torque specs are in the 15-20 lb/ft range (If I Recall Correctly).
Use a Torque Wrench that is accurate in that range.
They are Expensive bolts to shear off. (IE More expensive then a good torque wrench. If you plan to do any engine work, even just changing plugs, you need one that is accurate in the low end of the scale. These aluminum and plastic parts are easy to break.)
(Fondly recalling my old Shovelhead... every bolt had the same torque spec: 2 Grunts and a MF.)
Defend Our Hobby!
Join the SEMA Action Network
http://www.semasan.com
Old 31 Oct 2007, 12:31 pm
Strut bar is well worth the money, and easy to do - just, as noted, go EASY on the strut nuts.
Scuffing on top of BTG Strut Tower Brace purplept Turbo Wheels/Suspension/Handling 5 20 Jul 2004 05:26 pm
Strut Nut Problem with BTG Tower Brace purplept Turbo Wheels/Suspension/Handling 9 09 Jul 2004 08:06 pm
Strut Tower Bar and/or Anti-Sway Kit zzrogue Wheels, Tires, Suspension 4 04 Jul 2004 07:17 pm
January contest winners announced skylight General PT Cruiser Discussions 105 19 Feb 2004 02:39 am
Strut Tower Groan bigguigt Turbo Wheels/Suspension/Handling 20 15 Jan 2004 04:43 am
