PT Cruiser Forum Car Videos
Custom Wheels
After market parts
Old 16 Nov 2007, 08:33 am
Default After market parts
Hi Gang, I would like some feedback, my03 turbo has 75,000 and I just discovered the lower control arms (bushings) are shot. The dealer wants $1200 to replace which I thought was way too high. I found a web site called coolparts.com and they have them for $74.99 each, but I'm not sure if they come with the balljoints? anyone know about this? Thanks, Gary
Old 16 Nov 2007, 09:02 pm
CREWZIN CREWZIN is offline
Default Re: After market parts
Gary,
Why are you trying to replace the balljoints just because the bushings are shot?
Replace the whole set with polyurethane bushings .......
Energy Front Control Arm Bushing Set for 01-Up PT Cruiser (Fits lower control arm only) - PT Cruiser Accessories Store - PTCruiserClubStore.com
2000 PT. 95K miles, Original Owner
Old 19 Nov 2007, 08:16 am
Crewzin, I was told that the poly bushings sqeek some, plus the bushings are hard to replace, two mechanics said the labor is just as much to replace the bushings so you mine as well replace the entire assembly, I guess the ball joints come with the control arm anyway.....Gary
Old 19 Nov 2007, 08:33 am
MX-5 MX-5 is offline
Not true.
I've installed literally dozens of the poly bushing kits. No problems, no noises.
I would be willing to discuss this with your source for that claim.
At $400 installed for poly bushing on both sides, the cost is nowhere near complete control arm replacement. Have the shops that are quoting this actually done any?
Old 07 Jan 2008, 12:41 am
TheAnt's Avatar
TheAnt TheAnt is offline
Originally Posted by CREWZIN View Post
Gary,
How difficult is it for the shadetree mech to change these? My guess is that it involves releasing tension on some torsion bars. I can see an A frame bushing that looks like it is toast (if I can call it an A frame bushing). This is a 105kilomile 2002PT.
I also would expect to "rebush" the rear given the cracks on the sway bar? bushings.
I expect my struts need replaced but a pro whold have the tools that I don't.
The rear shocks should be a piece-o-cake.
Comments?
Can I change the bushings myself? Ball joints?
Old 07 Jan 2008, 11:14 pm
Cartman Cartman is offline
i dont see why you couldnt do it yourself. taking the control arms off is fairly simple. just make sure you have both wheels off the ground so you dont have tension ont he sway bar. when you get the control arms off, you can take them to a shop and have them press the ball joints and bushings off press in the new ones. that shouldnt cost very much at all. if you have a heavy duty ball joint press with a good assortment of adapters you can press everything on and off yourself.
06 Touring Edition NA/Auto. Airaid intake, Magnaflow Stainless cat-back exhaust, Taylor Thundervolt plug wires, rear lowered 1.75" with H&R Springs.
Yep, buying parts I cant afford with money I dont have to impress people I dont like anyways.
Old 08 Jan 2008, 12:14 am
TheAnt's Avatar
I may do the bushings myself and let a trusted pro do the ball joints. I really appreciate your help!
peace
Old 05 Mar 2008, 10:32 pm
TheAnt's Avatar
I bought some and got the control arm off... without disconnecting the knuckle... I won't do the other side that way!
Anyhow my rear pivot looks like it is moulded into an insert/sleeve that is pressed into the control arm. To remove it the way Energy says I would have to destroy the old rubber while saving the bug sleeve that is pressed into the rear control arm pivot. I expect some rubber to stay and can only think I have to buff the rubber off? The replacements look very different from OEM. I have pics.
vB code is On
Low Quality parts in these states - we're being frauded Wrenchhed Southeast PT Forum 6 16 Jul 2007 01:48 am
after market parts 1SLO PT General PT Cruiser Discussions 7 23 Aug 2005 02:21 pm
Mopar Parts Now Available For Dodge SRT4 skylight PT Cruiser News and Rumors 5 10 Sep 2003 10:33 pm
SRT-4 Mopar Performance Parts skylight PT Cruiser News and Rumors 13 23 Jul 2003 07:26 pm
Mopar Performance Parts Warranty Dalite Turbo Performance 0 07 Jun 2003 10:44 pm
  Credit Cards | Finance | Myspace Layouts | outdoor-clothing-catalog.com | Credit Cards
