welcome to the board !!
Welcome to the forum. If you read all through the forums, you come across many different problem but comparing them to the over a million sold, the problems are pretty wide spread. The most common ones are the multifunction stalk (cheaply made and a small part burns out which causes the fog lights to stay on); power steering pump or steering stalk ( pump fails or clicking noise when turning); chrome wheels rusting around edges which causes air too leak form tire; and last but not least, different parts fail which causes problems, example idle air controller, cam sensor and high pressure sensor for the air conditioning. On top of the list is multiple problems with idle and running because of the cheap plugs and wires that originally came with the PT from the factory.
Not all of these happen to everyone and some of us have seen none or one. I have 90,000 miles and had the cam sensor wires burn and the power steering pump fail. I've had a lot more things fail on my Corvette than on my PT. Don't abuse it, keep up preventative maintenance and enjoy the ride.
![]() ...just CREWZIN along! ® . . . PT Cruiser Links Moderator ![]() 2000 PT. 100,000 miles, Original Owner Visit My Home Page www.CREWZIN.com |
Welcome.
I'm on my second PT. Just to add to Crewzin's list - replace the ignition wires - suggest Crane wires afrom www.RaceAndStreet.Com and put in new plugs at the same time. Then you'll be set for a while. The other thing was the auto tranny - around 50,000 miles, get it flushed and the ATF + 4 fluid replaced. I just had mine done, cost about $175. You don't have to go to dealer, just make sure 1) mechanic has a machine that flushes (not just drains) the auto, and 2) be sure they use ATF + 4 (or ATF +5).
The ATF +5 is what Chrysler is calling the synthetic blend of ATF +4. I had mine flushed at 50K (now 90) with the synthetic. We all agree the auto tranny is a weak link and yes "ounce of prevention etc., but 50K doesn't seem unreasonable if your not beating your engine/tranny. Almost all of us use Mobil 1 or other synthetic and still change the oil way before it's due to go along with the prevention theory.
The engine is "supposed" to be an non-interference type so no catastrophic failure can occur but from what I've been told , the pistons can still know into the valves and cause damage. That's why I'm looking around now for a good deal on a timing belt change, along with an upgraded belt tensioner, water pump and normal belts.
Address your last comment first. The seats are chair like and at least for me, pretty comfortable. They don't have padding, pads and bolsters that sport seats have because the original intension of the cruiser was to "cruise", not to take corners like a race track.
My invoice for the tranny flush says 16 quarts of SYN/Fluid @ $4 per qt. plus 1 can of Flush @ $24. I watched the person doing it and instead of bringing all the containers of ATF+4, he had two brown boxes with red synthetic fluid with ATF/SYN written on the side. When I asked if it was ATF+4, he said it was the +5 synthetic. Now when they do the "flush", the can of flush which they run through the transaxle is supposed to clean the filter as they don't drop the pan & filter during the flush. I didn't like that. The next day I had them drop the pan and replace the filter. I had to pay for the labor, 4 more qts of +5, black adhesive (they used that to seal up the pan instead of a gasket) and hazardous waste disposal, but I felt better with having it done.
| New Member/First time PT owner | War_Eagle | General PT Cruiser Discussions | 7 | 17 Nov 2007 09:52 am |
| 2001 Dodge Stratus R/T Coupe*Low Miles*One Owner (hayward / castro valley) $10990 | skylight | craigslist | 0 | 15 Jul 2007 04:01 pm |
| 1st time pt owner w/exhaust question | Moto man | Tech & Performance Forum | 8 | 11 Mar 2005 05:22 pm |
| Recommended warm-up time | dbraveman | General PT Cruiser Discussions | 9 | 12 Feb 2004 09:38 am |
| Won't start first time | Mike Radowski | Turbo Performance | 1 | 14 May 2003 02:34 pm |
