PT Cruiser Forum Car Videos
Car Rims
Dash Light Bulb
  #31 (permalink)
Old 06 Apr 2008, 09:42 pm
jackfrisch jackfrisch is offline
Default Re: Dash Light Bulb
i never got the pdf file? nothing, do you have something to send or not?
  #32 (permalink)
Old 15 May 2008, 04:12 am
cdlazar cdlazar is offline
May I please have a copy of the instructions. Thanks
cdlazar@hotmail.com
  #33 (permalink)
Old 15 May 2008, 09:10 pm
LVActor's Avatar
LVActor LVActor is offline
May I request a copy too? Thanks.
lvactor@cox.net
  #34 (permalink)
Old 16 May 2008, 07:01 am
What I did was:
1st, gently pry out the window control module. Remove that screw.
Next, Pulled the knob off of the climate control section, pried out that cover.
There are two screws there hold the dash board cover on.
Then slid your hands beneath the steering column and panel, pop that down.
Removed the two screws to the left, removed that panel.
The panel between the windshield and door, long piece of plastic from dash board to roof, pry that off on both sides, driver and passenger.
Check for any other screws, in the area hold the dash board down, (there are 4 holding the instrument panel in, then lift and slide with gently force the dash board toward you. You should hear some noises as it comes out i.e. retaining clips popping/releasing.
Then pull of the instrumentation cluster cover, watch the odometer reset rod, unscrew the instrumentation cluster and pull toward you. Reinstall in reverse order.
Refer to the pictures in the beginning of this string as a reference.
Remember not to force anything and take your time.
Good Luck
Chuck
vB code is On
how does a newbie change a light bulb? neudorfshots General PT Cruiser Discussions 0 30 Jul 2007 01:09 pm
trac control & abs light staying on in dash bobs turbo pt General PT Cruiser Discussions 5 05 Apr 2006 05:31 pm
malfunction light on dash ajgarc Tech & Performance Forum 1 16 Feb 2005 08:18 am
Replacing fog light bulb Puck Exterior Accessories Forum 5 21 Sep 2004 02:27 pm
Vanity Mirror light bulb replacement Bren Turck General PT Cruiser Discussions 2 25 Jan 2004 08:46 pm
  Debt Consolidation | Theme | Cheap Car Insurance | Cheap Magazine Subscriptions | Mortgages
