How do you change the Headlight Bulbs on the PT
Old 24 Dec 2007, 04:23 pm
Default How do you change the Headlight Bulbs on the PT
Anyone know how?
02 Auto Trans PT Cruiser. APC Cold Air Intake. Flowmaster 40 Series. Chrome Tip. MX5-MOD
Old 24 Dec 2007, 06:24 pm
Default Re: How do you change the Headlight Bulbs on the PT
There is an access door in front of each front wheel on the wheel well. The Haynes book says remove the wheel and put the car on a stand for safety, but I just turned the steering wheel to get to it, without removing the wheel. You then turn the bulb holder to remove it and unhook the wiring plug. The new bulbs come with the holder attached. DO NOT touch the glass on the lamp, as the oil on your fingers can etch the glass and make the bulbs fail prematurely. Hope this helps.
Nick
Old 24 Dec 2007, 07:02 pm
if you do touch the glass, wipe the bulb with rubbing alcohol and a clean lint free cloth.
06 Touring Edition NA/Auto. Airaid intake, Magnaflow Stainless cat-back exhaust, Taylor Thundervolt plug wires, rear lowered 1.75" with H&R Springs.
Yep, buying parts I cant afford with money I dont have to impress people I dont like anyways.
Old 24 Dec 2007, 10:17 pm
soonercruiser's Avatar
Wink Re: How do you change the Headlight Bulbs on the PT
I found that the access, reaching and fitting your hand through that area is a key problem. Find someone with a long skinny arm & hand!
Old 02 Oct 2011, 11:50 am
Well I tried and tried today to get the high beam bulb out to no avail. I also tried to get the parking bulb out and failed again. In fact I cant find anything in the Haynes manual as to how to get the parking bulb out.
Shouldn't matter but it is a right hand drive car (UK)
Any other ideas welcome.
Old 02 Oct 2011, 12:22 pm
xwing777's Avatar
Are you twisting the holder counter clockwise? Its a quarter turn and pulls out of socket.
2004 Almond GT with autostick -Current Mods: lots
2006 Electric blue NA auto- Just starting to mod it!
Old 02 Oct 2011, 12:45 pm
I agree. I've changed both the headlight (to Sylvania Super White) and the turn signal bulbs (to chrome covered, which I've since changed back to OEM) and the only problem I had was to reach the high beam (which I really didn't need to anyway). The others just twisted and pulled out.
Old 02 Oct 2011, 12:58 pm
xwing777 - I cant even get my hands on the high beam to be able to twist it, maybe I have sausages for fingers, need to find a small person to do this perhaps!
Does the parking light also twist to come out (that is if I can ever get my hands on it!)
Old 02 Oct 2011, 02:04 pm
xwing777's Avatar
Yes, twist for all 3 bulbs. It helps if you take the other hand and pull down the plastic liner where the little door pops off as you put your other hand inside. The edge of the plastic catches on your hand as you stick it through the opening. If you got some kids in the neigborhood, get one of them to try it as it is really tight through that hole regardless.
Old 02 Oct 2011, 02:48 pm
Chromenut's Avatar
I pulled the wheel and loosened up all the forward screws on the splash guard/wheel well liner, then I could get to all the bulbs with minor problems. No more trying to twist my fat hand to fit that tiny opening!
...if I only had a brain...
I would need my own forum just to list my mods!!!
Remember, a PT Cruiser is not just a car, it's a way of life!
LAUS DEO SEMPER
Replacing Headlight Bulbs whitbyPT Exterior Accessories Forum 22 06 Nov 2010 06:33 pm
How do you get the cover off to change headlight. wyzard Tech & Performance Forum 3 29 May 2005 09:39 am
GE Nighthawk Headlight Bulbs rszappa1 Tech & Performance Forum 13 11 Nov 2004 06:16 am
Problems with Headlight bulbs KingKole02 Exterior Accessories Forum 18 26 Mar 2004 11:46 am
Headlight Bulbs gsharrock Exterior Accessories Forum 4 04 Jun 2003 11:33 pm
