The engine temperature Issue.
Old 25 Dec 2007, 06:34 pm
Default The engine temperature Issue.
HI.
I have 02 PT which is 110k on it. The heater do not blow the warm air to inside. When the car was stop, the warm wind comes out. However the car makes always cold air while the car was driving. Here is Michigan. The outside temp. is usually F20. The engine temp gauge stays cold position while the car is driving on the highway. It is horrible. Can't I drive in the winter season? What's wrong?
Thanks.
Old 25 Dec 2007, 08:55 pm
soonercruiser's Avatar
Default Re: The engine temperature Issue.
That sounds like the thermostat is stuck "open".
A PT with 110K on it needs some TLC - service! When was the coolant system flushed last?
Old 26 Dec 2007, 05:42 pm
Agree. Temp gauge should come up to 1/2 way - if it doesn't thermostat needs replacing.
Old 27 Dec 2007, 12:23 am
agree with sooner and quick. if temp reads normal, either your heater core is clogged or airlocked, the flap door inside the heaterbox isnt working, or it could be as simple as the cabin air intake in the cowl is clogged with debris.
06 Touring Edition NA/Auto. Airaid intake, Magnaflow Stainless cat-back exhaust, Taylor Thundervolt plug wires, rear lowered 1.75" with H&R Springs.
Yep, buying parts I cant afford with money I dont have to impress people I dont like anyways.
Old 28 Dec 2007, 05:17 pm
Another vote for the thermostat.
"Mysterious" turbo engine noise...??? Gary04GT Turbo Performance 76 21 Aug 2006 08:28 am
Review: $2200 for a NA replacement engine PT Ctown General PT Cruiser Discussions 8 24 Jul 2006 01:08 pm
Air Intake Temp using stock components Dalite Turbo Performance 16 28 May 2003 05:35 pm
