Please help, The On Board Diagnostic System has turnes on the light. I put a new gas cap on trying to fix the problem. No luck. I can not find any loose hoses. What problem with the automatic transmision turns on the light? Is this a problem many have had?
Thanks charlessundberg@msn.com |
Welcome to the forum Charles.
What fault code did the computer set when the malfunction light come on? This code will help us, help you in finding the fault.
Quicksilverdon,
Thanks for the input. I will do as you say and get the fault code. I will post the result. Thanks again, pnwptowner
Quicksilverdon,
The do it yourself fix was very helpful. When I ran the test I got no code just the "done". I was sucessful in extinguishing the light by removing the negative battery terminal for tem minutes to let the computer rest. Then reataching the lead and "vola" no light. I drove the car to the airport to dinner and home with no faults. If I knew where you where I would send you a bottle of Scotch. pnwptowner |
Good. It was probably just a 1-time misfire. It triggers the light, but sometimes doesn't generate a code. The light would've gone off by itself in time if the problem didn't recur.
where exactly do you start? I have 3 different areas to start~ once to put in the key, another to turn on the panel (senser, odometer and mileage) and the 3rd to turn on the engine. I did the first two starts, and the odometer window still comes up blank. *scratches head* guess I'll just have to go to Autozone and have that done hopefully for free.
2006 Electric Blue PT Cruiser (TE) ![]() Former owner of 2002 PT (Basic) Retro cars RAWK!
cruisinbabe,
The second click forward where the panel lights up is as far as you want to go. Make the panel "light up" three times and at the 3rd time it lights up leave the key pointing forward with the panel lit and it will either give you a code or say "done". One more thing, turn the key 3 times in a space of about 5 seconds. Don't hesitate between turns.
hunh...whaddaya know...?! I got the "done" message as well. I'll have my nephew check the battery when I get home.
| Error Codes | skylight | Tech & Performance Forum | 7 | 28 Apr 2011 03:34 pm |
| Car Gurus Lists Top and Worst Vehicle Retail Retention Rates | skylight | PT Cruiser News and Rumors | 5 | 08 Jun 2007 01:57 pm |
| Meet Me in St Louis on Route 66 2007 | skylight | PT Cruiser Events | 0 | 20 May 2007 05:09 am |
| Cruiserfest 2007 | skylight | PT Cruiser Events | 0 | 20 May 2007 03:31 am |
| 2007 PT Street Cruiser Announced | skylight | PT Cruiser News and Rumors | 0 | 16 Aug 2006 08:47 am |
