Replacing power steering
Old 22 Jan 2008, 09:27 pm
Default Replacing power steering
Hi everyone. I have a friend who needs the power steering pump replaced on her '01 N/A PT, being a car guy I thought I could help. I've never worked on PT before though, so I thought I would come on here and talk to you guys before I started.
I did a little research and it seems that this is a pretty common problem, but how big of an undertaking is it? Has anyone on here done it? Does anyone know of a how to or diagram that might be of any help? Thanks a lot.
Old 22 Jan 2008, 11:28 pm
Default Re: Replacing power steering
its not too awful bad to do yourself. it does take a while though. take off the wheel, take off the shields. take off the belt. youll have to move the ac compressor out of the way (you dont have to disconnect the hoses), take off the grille of the car, unbolt the upper tie bar. pull the radiator and condenser assembly up off of its mounts and pull it as far forward as you can. then disconnect the power steering hoses ( a good crowsfoot set is needed) then unbolt the pump and pull it out through the top betweent he radiator and motor. then just reverse all that to put it all back in. its not bad at all really. i just had to do one not too long ago. took a while to figure out how to get the pump out of the car.
06 Touring Edition NA/Auto. Airaid intake, Magnaflow Stainless cat-back exhaust, Taylor Thundervolt plug wires, rear lowered 1.75" with H&R Springs.
Yep, buying parts I cant afford with money I dont have to impress people I dont like anyways.
Old 23 Jan 2008, 08:41 am
Welcome.
Cartman's taken care of you.
Post pics of your friend!
Old 14 Feb 2008, 09:58 am
Unhappy Re: Replacing power steering
Hi,
My power steering is being a little fussy recently. It seems to work well at higher speeds but at lower speeds the assist is not very much. I was wondering if this is the pump not fuctioning properly or another part causing the difficulty. I see that you needed to replace the part, but did not describe the symptoms. I was hoping for some advice! 2003 PT Cruiser with 40,000 Miles.
Power steering whine problem identified sawdust123 General Turbo Discussions 5 10 Dec 2008 07:24 pm
Tranny Failed then Power Steering Switch? Sami_Girl_FL General PT Cruiser Discussions 22 19 Dec 2007 09:06 am
ATF + 4 or 5 for power steering? quicksilverdon General PT Cruiser Discussions 2 21 Feb 2005 05:00 pm
I think I'm having a power steering problem! lumofny Tech & Performance Forum 5 18 Jan 2005 01:12 pm
Power steering leak . . . gonzowing Tech & Performance Forum 5 15 Apr 2004 10:28 pm
