Gate Lock Malfunction
Old 28 Jan 2008, 08:35 am
hubtech's Avatar
Default Gate Lock Malfunction
Hello Everyone, i have a problem wen i try to open my Tail Gate from the outside it wont open.
the gear is on (P) all the other locks are open but i still have to use the key to open it.
the outer handle where i just press and it opens is not working.
please can anyone advise what to do because it is frustrating to turn off the car and remove the key to open the tail gate from the outside everytime.
Old 28 Jan 2008, 08:47 am
Default Re: Gate Lock Malfunction
What year? They changed the opening from mechanical to electric I think in the '05 model.
Old 28 Jan 2008, 09:08 am
hubtech's Avatar
2007 i wish i could solve this problem.....
Old 28 Jan 2008, 09:34 am
Some similar problems:
The Trunk Problem Thing
Hatch latch malfunction
With an '07, you should make dealer solve the problem.
Old 28 Jan 2008, 09:59 am
hubtech's Avatar
The problem is that i am in Libya with my car and there is no specific dealer for Chrysler and i cant take it to anyone because i know they will bust it up.
so thats why i am seeking help to do it myself.....
Old 28 Jan 2008, 11:42 am
Okay.....
If you read the posts, pulling fuse for RKEM (Remote Keyless Entry Module) helped in at least one case.
Old 28 Jan 2008, 05:29 pm
soonercruiser's Avatar
If the posts above don't help, I'd leave it alone and use the key until you get back to the states.
Old 10 Feb 2008, 03:52 am
hubtech's Avatar
Thanks Sooner but i cant because i live here, if anyone could explain or send a diaghram of all the connections and fuses to the gate lock and i'll try to figure somthing out.
Old 10 Feb 2008, 05:15 am
hubtech's Avatar
can u tell me where the pulling fuse for the RKEM is located.
Old 10 Feb 2008, 10:09 am
Wish I could help but it's probably way different on your 07 compared to my 01. In mine, there's 2 fuses for the RKEM. One fuse inside the car, the #3 fuse and there's the #10 fuse in the box in the engine compartment.
The little door on the inside fuse compartment has an imprint on the inside of the door with abbreviations of what each fuse is for. Your owners manual has a diagram and list of what the fuses in the engine compartment control.
Driver side door lock problem KTBoom2006 General PT Cruiser Discussions 5 13 Oct 2006 08:19 am
to lock or not to lock dcartwright PT Cruiser Convertible Forum 0 01 Jul 2005 03:27 pm
Tranny She is a no-good! scottscars Stage Turbo Kits 15 16 Oct 2004 11:11 am
Easy Lock Maintenance streetrods General PT Cruiser Discussions 5 25 Dec 2003 03:04 pm
