My 2003 PT GT keeps blowing the one of the a/c seals. The mechanic says the pressures on the high and low sides are nearly the same. When the seal is replaced, the unit works well, so I don't know if the pressure problem has always been there. Anyone experience anything similar?
sounds like you have a bad orifice tube. the pressures should not be the same on the high and low side, hence why theyre called the high and low sides. which seal is blowing exactly?
06 Touring Edition NA/Auto. Airaid intake, Magnaflow Stainless cat-back exhaust, Taylor Thundervolt plug wires, rear lowered 1.75" with H&R Springs. Yep, buying parts I cant afford with money I dont have to impress people I dont like anyways. |
The seal is an o-ring in a block located on top of the engine where the lines connect.
If it's a bad orafice tube, how does it go bad? Also, is there a drier in the system that needs to be replaced? |
tubes get clogged or o-rings blow apart or the variable orifices get stuck full open. cheap little parts located in an expensive line.youll have to buy the whole liquid line to replace the orifice tube if that is your problem. as for your drier, unless the system was contaminated with moisture or was open for a long period of time, you should need to replace it. if the system did have moisture in it, then it should be replaced along with about an ounce and a half of refrigerant oil.
| Electronic Portable Air Conditioner | h.fork | Classifieds: For Sale/Trade | 1 | 29 Sep 2006 09:08 am |
| air conditioner smell | aimee_in_TN | General PT Cruiser Discussions | 9 | 17 Jun 2004 11:02 am |
| Conditioner VS Dressings | turbomangt | The Detail Shop | 0 | 22 Feb 2004 11:05 am |
| cabin fresh air filter = noisy air conditioner! | alceryes | General PT Cruiser Discussions | 17 | 24 Dec 2003 02:00 am |
| Air Conditioner Compressor | PT 7 | General PT Cruiser Discussions | 5 | 24 Jul 2002 06:40 pm |
