Spark Plug Guide MISSING!
Old 17 Feb 2008, 01:32 pm
Unhappy Spark Plug Guide MISSING!
the image host for the spark plug walkthough is permenatley down
I just bought some Champion double platinums and was about to go buy the wires so I could change them out this afternoon.
just wanted to double check the guide and poof..now it's gone.
did anyone by chance ever save these images? perhaps we can host them here on this board..
Old 15 Mar 2008, 06:02 pm
Default Re: Spark Plug Guide MISSING!
Yeah, we too have noticed quite a few dead external links in this "links" forum
~Steven & Eva
Old 16 Mar 2008, 06:46 am
Yes, Imagestation posted about a month ago that they were going down and everything would be gone. I guess nobody had the forsight to save the pictorial about changing wires and plugs.
Old 16 Mar 2008, 08:24 am
The guide I wrote 7 years ago is still online at www.ptdiy.net
Old 16 Mar 2008, 08:46 am
Sorry Mike. Correction: I guess nobody had the forsight to save the FREE pictorial about changing wires and plugs, but it's still available at www.ptdiy.net courtesy of Motor Mike
Old 16 Mar 2008, 08:50 pm
Well I finally got around to changing the wires and plugs today.
What was funny was that I was looking for the EGR valve in the back of the manifold....I guess that is a turbo thing cuz there was a space for it on my manifold but it was plugged up.
so..undid the five 8mm bolts up front...the one 13mm bolt in the back..and the three 10mm bolts on the throttle body. then i pulled it upwards with a bungee.
no probs other then this one scary moment when I thought a bolt was going to fall into the lower intake
put it all together and took it for a spin..ran just as good as before...we'll see if the MPG improves.
FYI it's a 2005 limited non-turbo bout 40k..still had stock plugs and wires.
upgraded the plugs to Champion Double Plataniums..the wires were not exactly an upgrade. had to settle for AutoZone Duralast wires...they look a bit thicker have an extra cover over the wires and a lifetime warranty...just hope they are not worse then my stock. (they were 29.99 btw)
So with my K&N drop in...hope to up the MPG.
Before I would get anywhere between 280-310 miles on a full tank depending on the a/c usage and how heavy my foot is...
what do we have? a 14 gallon tank? that between 17-20 mpg.
lets see after a week how these do.
thanks again for the help guys
Old 16 Mar 2008, 09:29 pm
Your right about the EGR pipe in the back. Chrysler did away with it in 2003 so it's a lot easier without it.
Old 16 Mar 2008, 10:04 pm
15 gallon tank.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Old 17 Mar 2008, 08:41 pm
It's a good idea NOT to let the tank get below 1/4 tank. The fuel cools the fuel pump and if it gets real low the pump will burn out. $200 to $300 to repair.
spark plugs ote69 Turbo Performance 28 11 Jul 2010 09:59 am
Spark Plug Guide.. thegoldpt Tech & Performance Forum 1 07 May 2008 04:53 am
spark plug wires dzinman Tech & Performance Forum 1 28 Jul 2005 01:25 pm
Spark Plug Wires what should I do? KingKole02 Tech & Performance Forum 17 12 Jan 2004 11:06 am
spark plug cracked heeeelp!!!! ptcruz311 Tech & Performance Forum 5 25 Sep 2003 02:12 am
