PT cruiser Hatch spoiler install help needed
Old 04 Mar 2008, 07:08 pm
Default PT cruiser Hatch spoiler install help needed
Hi I found a 2003 PT cruiser rear spoiler in my colour how do I install it?
PT Cruiser Inferno Red GT Cruiser. 5Spd 215HO HP 17" Chrome wheels, Chrome gas cap, door spears, door handle cups, door buttons,door lock pins, vent covers,rear spoiler,rear painted mudflaps,, chrome/carbon fibre/like ebrake cover, wiper jet covers,bra, seat covers,Mr. Mikes welting, chrome valve stems and caps, leather ebrake boot,chrome change holder cover,black/red leather steering wheel cover, chrome antenna bezel and chrome 12:" antenna,rear quarter window decals, winter car cover for winter storage, special made DREAM CREWZER dash plaque.upper windshield eyebrow tint , gts headlight protectors, carbon fibre taillight covers,car cover,K&N drop in filter, AMX intake pipe, shiny metal steering wheel spoke covers:Mopar door sills, rear chrome licence insert.street series badge,billett grill,engine start button, red brake calipers,painted engine manifold,chrome vent knobs,chrome/carbon fibre shift knob
Old 04 Mar 2008, 08:14 pm
Default Re: PT cruiser Hatch spoiler install help needed
If it's like my 2001 look at the corner of the hatch when you lift it up and you'll see two small round black plugs. They cover up holes that allow access to the bolts that go through the hatch into the ends of the spoiler. New spoilers have a template that attaches to the outside of the hatch and shows where the holes are to be drilled.
Old 05 Mar 2008, 12:48 am
I checked...my 2003 GT does not have any black plug holes...now what???
Old 05 Mar 2008, 01:45 am
ucantcme's Avatar
Send a message via AIM to ucantcme Send a message via MSN to ucantcme Send a message via Skype™ to ucantcme
I just bought a spoiler and brought it to a body shop, they drilled the holes and everything.
I didnt have those plugs either
My Baby:
01' Taupe Limited PT Cruiser w/ rear spoiler, Drop in K&N Air Filter, Limo tint all around, blue neon interior, blue LED windshield nozzles,
In-dash CD/DVD/Radio made by Jensen, Vent Visors, Chrome Antenna Bezel, Chrome Grille inserts, Dual Catback Exhaust, Scan Gauge II,
back-up camera, and a system containing 2 Lanzar 15" subwoofers and an MA Audio 1800watt amplifier.
Check me out on Car Domain!
Old 05 Mar 2008, 07:32 am
Don't know what to say except that you might have to take a trip to the body shop too, like ucantcme. Do you have the nuts and bolts that attach the spoiler to the hatch? If so, you can always get someone to help while you measure, fit and drill the holes yourself.
Use the old saying: measure twice, cut (drill) once.
Old 05 Mar 2008, 09:51 am
Take it to a body shop. They have the expertise and equipment, if something goes wrong, its their problem.
Old 05 Mar 2008, 01:08 pm
soonercruiser's Avatar
Thumbs up Re: PT cruiser Hatch spoiler install help needed
Just mounted an aftermarket spolier on the 2006 soonercruiser. Son and me (a rookie to this myself) did it ourselves. The critical part is.... did the spoiler come with the mounting bolts?
-Then it's just a matter of creating a template to carefully place the spoiler, look at it from several vantage points, and drill the holes in the correct place. What you want is...something that you can stick into the mounting holes in the spoiler, then that item/template is left behind as you lift the spoiler off....indicating exactly where to drill the holes. Be sure round/soften the hole edges and paint the hole edges with an enamel paint to reduce the chance of rust.
-Oh! And be sure the under surface of the mounting of the spoiler has a gasket to further prevent leaks thru the mounting holes into the hatch.
**Mine was even more difficult, since I custom molded-in an LED light into the spolier, and we had to run the wire to the 3rd brake light.
(thanks again Carey)
Frank Lipsinic soonercruiser Photo Gallery - PT Cruiser World
Old 05 Mar 2008, 05:23 pm
I had a spoiler installed on my 2002, the problem I noticed later was that the wiring on the drivers side, the rubber sleeve wore thru. Didn't bother the cables tho, as I taped the rub spot with black electricians tape.
Old 05 Mar 2008, 06:00 pm
I have a copy of a template if you need one. I can fax it to you.
Frank
Old 06 Mar 2008, 12:37 am
Thanx Frank I emailed you a fax no.
2004 Chrysler PT Dream Cruiser Series 3 skylight PT Cruiser News and Rumors 10 18 Jun 2009 08:57 am
PT cruiser Hatch spoiler careyk Classifieds: Want To Buy 2 11 Mar 2008 01:37 pm
PT cruiser Hatch spoiler careyk Canada PT Forum 0 30 Jan 2008 06:27 pm
Rear Hatch Opener Install ? StevenAndEva Sound and Security Forum 1 24 Feb 2006 12:23 pm
New 2005 Convertible PT Dream Cruiser skylight PT Cruiser News and Rumors 4 11 Jan 2005 06:12 pm
