I have a question...
Old 13 Mar 2008, 01:14 pm
Default I have a question...
So I am starting the car the other day, and I noticed on the fuel gauge and thermometer gauge there is a little red light that lights up when I first start the car. I noticed that if I leave the key in on position it goes out after a few moments.
Also we have some issues sometimes where the car has a hard start. But if I wait for this light to go out, the car starts easier and right away.
I know that desiel engines require a heat coil to go before starting, but I have never heard anything about regular gas engines. Does this light have anything to do with starting the car, or is it just coincidence?
Old 13 Mar 2008, 01:46 pm
Default Re: I have a question...
Your little red light has nothing to do with starting the car. It's the built-in alarm system. If you stand outside the car, hit your remote lock, the light comes on to show you the alarm is on. It goes out after a couple minutes. When you start the engine, that light and a few others come on for a second or two then they all go out if nothings wrong with any of the systems.
The electric fuel pump probably has more to do with why you start up easily with waiting a few seconds. Waiting a few long seconds with the key in the ON position gets the fuel pump working and gets your fuel pressure UP enough to get the engine going. It just happens to coincide with the time you wait for the red light to go off.
that little red light in the dash is for the theft system, what it indicates is that the ignition key that is in the ignition is correct for that vehical or programed for it depending on how you want to say it.
if the light was to stay on and a no start was to also happen it would meen the the key hasn;t programed for the vehical.
and yeah if you wait a second for the light to turn out it means that all the controlers have had a chance to verifie that it sees the right key.
so if the little light goes out nothing to worry about.
PT / SRT-4 Rear Sway Bar Question Maxxam Turbo Wheels/Suspension/Handling 11 13 May 2008 02:29 pm
Warranty Question Opiate General PT Cruiser Discussions 4 27 Nov 2004 10:06 pm
Question about E & G grills coopj40 Exterior Accessories Forum 3 14 Jun 2004 01:43 pm
question about head unit upgrade Avus Sound and Security Forum 1 08 Jun 2004 06:32 pm
Gasoline question Sleighboy Turbo Performance 13 07 Mar 2004 06:40 pm
