Timing belt replacements ??
Old 17 Mar 2008, 02:43 pm
Default Timing belt replacements ??
When should you replace a timing belt in a non-turbo pt ??? mine came without a manual book ...
Old 17 Mar 2008, 06:00 pm
Default Re: Timing belt replacements ??
Crewzin posted this a few months back:
"My 01 says 120,000 but I'm not waiting that long and at 90K now, I'm looking around for the right place to do it. If you did a search you probably already saw that the regular drive belts, belt tensioner, water pump, oil pump and engine mounts should also be looked at real closely as they might be in need of changing also."
Ben
2001 Red PT Cruiser Limited, 16" OEM alloys, Airaid CAI, Screamin' Demon coil and Livewires, some shiny stuff inside, Alpine deck, Alpine four channel amp, Alpine PLT5 sub, Hertz speakers in 4 corners, Keystone ram air hood, 6000k 55w HID high beams, 6000k 35w HID fog lights, new stone chips every day to add character.
2007 Suzuki King Quad 700 4x4 for when the road gets bumpy.
Old 18 Mar 2008, 05:58 am
im only at like about 45K on an 02 limited so i guesse im ok for now till i sell it ...
[IMG][/IMG]
Old 18 Mar 2008, 11:12 am
Be advised that this is not a "fun" job and it is very tedious and time consuming. Almost all the fluids except oil need to be drained, A/C & radiator, the engine jacked up to get at one of the mounting bolts. My mechanic was super pizzed at what was involved.
Good luck,
joel
The Pair-A-Dice PT, "my car is cleaner than yours"also more likely to burn!
Timing Belt Replacement MarkB Tech & Performance Forum 108 08 Aug 2017 12:59 am
Timing Belt Replacement Instructions PTFever Tech & Performance Forum 46 10 Aug 2015 10:33 am
Timing belt kills air conditioning customer20 General Turbo Discussions 9 19 Jul 2009 08:19 pm
02 2.4L timing belt problem ronwins3 Tech & Performance Forum 18 15 Dec 2008 08:57 pm
Another timing belt question thread :) ??? Ctown General PT Cruiser Discussions 4 24 May 2005 08:50 am
