Transmission Downshift Problem (2001 Automatic)
Old 06 Apr 2008, 03:59 pm
Default Transmission Downshift Problem (2001 Automatic)
First off, Hello. I am new to the forums and looking for some help for my parents. They have a 2001 PT Cruiser Limited. They have had this problem before and had it fixed by the factory. When you are slowing to a stop, the car will lunge into gear. It is not at every stop but most of the time.
The problem was fixed about a year and a half ago and has recently reappeared. It was first thought to be a simple transmission fluid change needed, but ended up needing to be the transmission valve-body changed.
Just wondering if this is an isolated incident or a common problem? To have the exact same problem spring up after only 1.5 years seems a little ridiculous.
Looking forward to your replies,
Adam
Old 08 Apr 2008, 07:30 pm
Default Re: Transmission Downshift Problem (2001 Automatic)
Some clues, please - how many miles?
What year?
The transmission is computer-controlled, might be that.
Could be the clutch packs.
Could need new transmission fluid.
Old 09 Apr 2008, 03:01 am
]Some clues, please - how many miles? 65,000
What year? Title says 2001 automatic
The transmission is computer-controlled, might be that. I did mention that the first time this happened that it was the transmission valve-body that had to be replaced. That was 5-10,000 miles ago.
Could be the clutch packs. I appreciate you throwing these ideas out. I am more looking to see if this is a reoccurring problem with PT's in general. Does not seem right to have to spend $800 every year or 2 on a transmission.
Could need new transmission fluid. Tried this the first time. Did not help and had to have the valve-body replaced.
Old 09 Apr 2008, 05:36 am
ucantcme's Avatar
Send a message via AIM to ucantcme Send a message via MSN to ucantcme Send a message via Skype™ to ucantcme
Never had a problem like this on my Cruiser, nor have I heard of it recently on the forums....
My Baby:
01' Taupe Limited PT Cruiser w/ rear spoiler, Drop in K&N Air Filter, Limo tint all around, blue neon interior, blue LED windshield nozzles,
In-dash CD/DVD/Radio made by Jensen, Vent Visors, Chrome Antenna Bezel, Chrome Grille inserts, Dual Catback Exhaust, Scan Gauge II,
back-up camera, and a system containing 2 Lanzar 15" subwoofers and an MA Audio 1800watt amplifier.
Check me out on Car Domain!
Old 09 Apr 2008, 07:15 am
Are you sure they used ATF + 4 ? The Chrysler transmission is very fussy about tranny fluid. If they went to a dealer, that's okay, but some shops may not know.
The symptoms you describe aren't common.
Maybe ask around for a good transmission shop and have them give an opinion.
Old 09 Apr 2008, 10:51 am
Yeah, It was a dealer who replaced it. I appreciate the replies. Must just be a gremlin in this one.
Old 09 Apr 2008, 11:46 am
ok so what was replaced last time? the whole transmission or just something like a soliniod pack?
and the other thing is, with these transmissions being computer controled you need to have it scanned to see if there are any trouble codes in the transmission control module... not all trans codes will turn the engine light on.
also if the tech knows what he is doing he can look at the sensor info to see if there is a problem there. sensors being off will cause drivability problems but not always set a fault.
so long and short of it all your going to have to take the car in to either a good dealer or good transmission shop simple because with automatic transmissions there are to many fault posibilites to diagnois over the internet.
Old 09 Apr 2008, 03:35 pm
Are you serious? Are you even reading my post? This is almost funny.
Old 11 Apr 2008, 10:55 am
My hunch - clutch packs, but don't go by that - agree w/Frosty that good diagnosis is needed.
Old 04 Aug 2008, 09:03 pm
I just want to say that you're not the only one having this problem. There are other posts on this very site where people are inquiring of this issue. Sad to say, there hasn't been any solution yet.
My friend came to me about her problem with this. Not being a fan of Chrysler transmissions I nearly didn't accept the task of helping her find a solution.
I have checked for codes and came up empty handed. I am going to attempt to reset the computer (another forum suggested this by disconnecting the battery and pumping the brake 3-4 times, wait 5 minutes, then reconnect. After which you should drive it around and, in my interpretation, drive it like you stole it!). I doubt that this will be permanent solution.
She just took it in to change the fluid and filter. Obviously no resolve. My only guess is that there are some bad sensors (or Chrysler transmissions just suck!).
I feel sorrow for those that say they've learned to live with it!
Oh, and I also feel your irritation with people that don't read the whole thread, or others for that matter, before they respond.
transmission problem after rear-end accident dalipardon Tech & Performance Forum 12 05 Apr 2007 12:26 pm
Transmission downshift problem Floyd Harris Tech & Performance Forum 5 05 Jul 2006 07:18 am
Transmission problem turbotime Tech & Performance Forum 3 13 Nov 2005 06:28 pm
"Internal Transmission Problem" ??? yobiebs General Turbo Discussions 18 21 Oct 2003 11:17 pm
Transmission Downshift harsh ptcignaboi Tech & Performance Forum 4 23 May 2003 09:23 pm
