Leaky Sunroof
Old 07 Apr 2008, 05:04 pm
Default Leaky Sunroof
I did a search but was not able to find what I am looking for.
The passenger front side of my 02 sunroof is leaking. The leak seems to be at the right at the right front corner. I think that most likely it is a clogged drain as there is no leaking on the drivers side.
Does anyone have any advice on how to proceed in diagnosing the problem and fixing it?
Thanks in advance.
Old 07 Apr 2008, 05:08 pm
ucantcme's Avatar
Send a message via AIM to ucantcme Send a message via MSN to ucantcme Send a message via Skype™ to ucantcme
Default Re: Leaky Sunroof
Are your seals good/worthy enough to hold out rain? Maybe a tear in the seals??
My Baby:
01' Taupe Limited PT Cruiser w/ rear spoiler, Drop in K&N Air Filter, Limo tint all around, blue neon interior, blue LED windshield nozzles,
In-dash CD/DVD/Radio made by Jensen, Vent Visors, Chrome Antenna Bezel, Chrome Grille inserts, Dual Catback Exhaust, Scan Gauge II,
back-up camera, and a system containing 2 Lanzar 15" subwoofers and an MA Audio 1800watt amplifier.
Check me out on Car Domain!
Old 07 Apr 2008, 06:16 pm
It's either the drain or the seal. If if drips in a slow rain, it's probably the drain. If it only leaks in heavy rain, then a seal would be main culprit.
Old 07 Apr 2008, 07:12 pm
mjb457's Avatar
DUCK TAPE,,just kidding-sounds like seal.
Old 07 Apr 2008, 10:56 pm
drain. a little compressed air will clear the clog. 35 psi is plenty.
06 Touring Edition NA/Auto. Airaid intake, Magnaflow Stainless cat-back exhaust, Taylor Thundervolt plug wires, rear lowered 1.75" with H&R Springs.
Yep, buying parts I cant afford with money I dont have to impress people I dont like anyways.
Old 08 Apr 2008, 04:19 pm
i agree check the seal !!
Old 09 Apr 2008, 09:23 am
I checked the drain. It may have been partially blocked as it was draining some and then there was a gurgling noise and it started draining at a much faster rate.
The seal looks good. It is still soft with no visible tears. Both the passenger side that leaks and the drivers side which haven't leaked look to be in the same condition.
It has only leaked in heavy rain. But perhaps this was due to a partially blocked drain.
What is the best way to test the seal, turning a hose on it? And how much if any water should get past the seal when hosed? Should it be totally dry or is a small amount of water that the drain can handle to be expected?
Thanks for all the advice so far. It has been very helpful and informative.
Old 09 Apr 2008, 05:32 pm
I am becoming resigned to the fact that I have a bad seal.
Has anyone replaced one? Is it a DIY or should I bring it to a glass shop? And what should I expect to pay at a shop?
Aftermarket Sunroof PT GEEZR Exterior Accessories Forum 5 01 Apr 2008 01:14 am
Guide: 2006 Power windows and Sunroof always on. zapwizard General PT Cruiser Discussions 3 21 May 2007 09:23 am
Universal Sunroof. Raises up & can be removed! Wicked_PT Classifieds: For Sale/Trade 2 12 Jul 2006 07:24 pm
Sunroof W/Roofrack??? knowyourturbo Exterior Accessories Forum 9 12 Oct 2003 11:02 pm
Sunroof Question bemo General PT Cruiser Discussions 16 11 Jun 2003 12:26 pm
