Engine painting...
  #21 (permalink)
Old 12 May 2009, 05:52 pm
DIYPTGUY's Avatar
Send a message via AIM to DIYPTGUY
Default Re: Engine painting...
The reason I ask if the touch up paint will work is because the guys I asked at autozone said it may flake off when it gets hot. True? This is pretty much what you guys are using correct?
My Love:
02' Gold PT Cruiser Touring: Pioneer DEH-P4000UB Reciever, Self built subwoofer enclosure w/pioneer TS-SW841D subs, Summit Turbo Muffler, Spectre Modular Air Intake, underseat neon lights, subwoofer neon strip lights, Intake Manifold Paint, exterior chrome trim, steering wheel cover.
  #22 (permalink)
Old 14 May 2009, 05:18 am
PTPatrick1985's Avatar
Send a message via AIM to PTPatrick1985 Send a message via Yahoo to PTPatrick1985
Originally Posted by StoneWhitePT2 View Post
Yeah I had to paint the door sills and rear exhausters too....
How did you take these out ? I'm always afraid of breaking something or not being able to put it back together
  #23 (permalink)
Old 15 May 2009, 03:16 am
yteka99's Avatar
Send a message via AIM to yteka99
Idk about these parts specifically but ive found pretty much all parts im my 01 are just clips and if you pull them and they got a little give you can just pull em off. If theres no give, look for screws than try again lol probably not the best way but it works
rockin grampa's pt
  #24 (permalink)
Old 17 May 2009, 02:47 pm
YoungCruiserrr's Avatar
Send a message via AIM to YoungCruiserrr
How did you pop these off? I think I would like to paint mine for fun
2005 Brilliant Black
PT Cruiser Touring Edition
34,000 Miles.
  #25 (permalink)
Old 17 May 2009, 10:04 pm
yteka99's Avatar
idk im going out in a little bit ill see if i can just pull these off too. These are in the door ways when you open the doors riht?
rockin grampa's pt
  #26 (permalink)
Old 18 May 2009, 06:00 am
yeah, two by your feet, and two kinda up on the wheel well on the inside of back doors.
34,000 Miles.
  #27 (permalink)
Old 18 May 2009, 08:13 pm
Anyone have success ripping them off yet ? I'm not touching the door sills until I know what they are held on with. They don't budge at all.
  #28 (permalink)
Old 18 May 2009, 09:37 pm
Yeah I'm not a fan of pulling something till it rips off and then finding out how it was held down
34,000 Miles.
  #29 (permalink)
Old 19 May 2009, 03:13 am
StoneWhitePT2's Avatar
Front ones...All you gotta do is use a flathead screwdriver where u have something on the tip to protect the paint and stick it under one end to pry it up just enough to get ur fingers under it and just yank up, they will just snap off slowly, the plastic snap clips are molded under it(front/middle/back) so its almost impossible to break them.
The rear ones... there is only 1 clip which is at the top. you have to be very careful because the the clip is fragile. just take a small flathead screwdriver and pry it out slowly from the top edge directly in the middle where the clip is holding it down. make sure u cover the tip of the screwdriver with something so u dont scratch the paint... Pretty easy tho but i was nervous just like you guys at first, just take your time.
--See My PT In Action!!! http://www.youtube.com/watch?v=ppP_V9udtho
2002 Custom Dream Cruiser Series 5 Rollin 22s/20s
Replacing Timing belt: Engine support question cardana24 Tech & Performance Forum 4 21 Mar 2008 07:55 pm
"Mysterious" turbo engine noise...??? Gary04GT Turbo Performance 76 21 Aug 2006 08:28 am
Review: $2200 for a NA replacement engine PT Ctown General PT Cruiser Discussions 8 24 Jul 2006 01:08 pm
Engine problem BORICUA Tech & Performance Forum 49 03 Apr 2006 05:15 am
TSB 1802903: Engine Misfire PTskilla General Turbo Discussions 0 18 Aug 2003 12:13 am
