PT Cruiser Forum Car Videos
Car Rims
cost for replacing lower control arm bushings
Old 10 May 2008, 09:27 am
tm05cruiser tm05cruiser is offline
Send a message via AIM to tm05cruiser
Default cost for replacing lower control arm bushings
Just got my wifes 05 cruiser back from the dealer , they replaced the rack and pinion ,under warranty ,after i made a call to Chrysler. Anyhow, she came home from work the other day, and said when she takes off from a stop , she was sometimes hearing a clunk. So i took it for a ride , not all the time , but sometimes on a fast start i would hear it. So i took it home pulled the wheel, and sure enough the lower control arm bushings are junk. It goes in for Pa inspection on tuesday , so i was wondering what i can expect to pay to have these replaced. And also , its the drivers side , the passenger side look ok. But should i have both sides done. Thanks
Old 10 May 2008, 10:33 am
Taggert_LOA's Avatar
Taggert_LOA Taggert_LOA is offline
Send a message via AIM to Taggert_LOA
Default Re: cost for replacing lower control arm bushings
it's about 45.00 for the engergy suspension front LCA kit. and about 4.00 for a tube of marine grease. if the ball joints are good thats about it. if the ball joints are bad. ie; torn boot you have to replace the ball joints as well. they are 51.00 a set here: Chrysler PT Cruiser Ball Joint | Free Shipping | 2001 - 2005, Moog, Mevotech (get the MOOG they are usa made not cheap china shit) you'll need to press the old joints out and the new in. the new ones are serviceable. you'll never change them again. so i'd say about a 150.00 if you don't have a ball joint press and 115.00 if you do. also there is a nice write up over on ptcrew.com on how to replace the bushings in your LCA's. hope this helps. good luck.
"Every civilization finds it necessary to negotiate comprimises with it's own Values"
Old 10 May 2008, 06:11 pm
ucantcme's Avatar
ucantcme ucantcme is offline
Send a message via AIM to ucantcme
I had the same EXACT problem. I took it to the repair shop I last had it worked on - The mechanic said he tighten a few loose bolts, and that did it. This was not 2wks after my lower control arms were replaced, and my wheel bearings were done.
Your one stop Gaming Forum!
My Baby:
01' Taupe Limited PT Cruiser w/ rear spoiler, Drop in K&N Air Filter, Altezza Tail lights, Limo tint all around,
In-dash CD/DVD/Radio made by Jensen, Vent Visors, Chrome Shift Plate, Chrome Antenna Bezel, Chrome Grille inserts,
back-up camera, and a system containing 3 MTX 10" subwoofers and an eclipse 1000watt amplifier.
Wish List: Aftermarket tires/wheels, turbo!
Old 10 May 2008, 09:27 pm
2004PTCruiser 2004PTCruiser is offline
Taggert_LOA where is that wright up on how to repair lca on the ptcrew site?
Old 11 May 2008, 09:41 am
yes there is.
Old 11 May 2008, 06:04 pm
ucantcme's Avatar
I think he asked "where" not "no there isn't".
My Baby:
vB code is On
Check Engine Light came on - code 1188? coolvirus General Turbo Discussions 18 09 Jan 2008 01:14 pm
problems with lower control arm bushings ValAir Turbo Wheels/Suspension/Handling 34 31 May 2007 03:44 pm
obd-II codes Punch General Turbo Discussions 5 06 Nov 2003 02:34 pm
  Personal Loans | Myspace Layouts | Mortgage | Pay Day Loans | Mortgages
