Where is the voltage regulator? inside the alternator or inside the ECU? My model is 2003 touring edition.
Quote from the Haynes Manual:
The Voltage Regulator is an integral part of the PCM and cannot be replaced separately. |
That is common failure on the PT's? The only way is replacing the entire PCM? How much a PCM????
![]() Quote:
The only way is replacing the entire PCM? Seems that way, YES. A lot of vehicles have the same set-up. How much a PCM???? Not sure. Check with your local dealer and a couple auto parts places. |
what problem are you having exactly, and what leads you to believe that it is the voltage regulator to be the problem?
06 Touring Edition NA/Auto. Airaid intake, Magnaflow Stainless cat-back exhaust, Taylor Thundervolt plug wires, rear lowered 1.75" with H&R Springs. Yep, buying parts I cant afford with money I dont have to impress people I dont like anyways. |
Thread Tools | |
Display Modes | |
Check Engine Light came on - code 1188? | coolvirus | General Turbo Discussions | 38 | 25 May 2011 09:01 am |
Error Codes | skylight | Tech & Performance Forum | 7 | 28 Apr 2011 03:34 pm |
Error Codes | thegoldpt | Turbo Performance | 6 | 07 Apr 2007 02:26 pm |
Error Code List | skylight | General Turbo Discussions | 6 | 07 Apr 2007 02:11 pm |
Volt meter | OurPTGT | General PT Cruiser Discussions | 7 | 28 Jul 2003 09:09 am |
