Both the headlight and tail light covers on my 2002 PT retain moisture. (We live in New Orleans, a subtropical climate...very humid conditions.) Water droplets form under the covers, both clouding them and causing lights to blow...3 times in the last couple of months.
Any ideas on how to keep the moisture out of the tail lamps and headlights? Do they make any sort of rubber gasket to fit? |
The lights are supposed to be sealed to keep the moisture out. How about making a small hole or a couple small holes in the housing of each of the lights affected to let more air in to dry up the moisture?
A couple of the aftermarket taillights that I've had over the years actually had small tube like appendages about 1 inch long as big as a thick straw to let air/in/out.
![]() ...just CREWZIN along! ® . . . PT Cruiser Links Moderator ![]() Visit My Home Page www.CREWZIN.com |
Sealed? The ones on mine are nothing more than a plastic lens that fits directly against the metal part of the car. I'm afraid if I drill a few holes the lens would either crack or allow water to go directly into the assembly.
What are yours sealed with? Needs to be something there, for sure. |
With your subtropical climate where you are, it's enough to cause condensation to form inside each light.
a 50/50 dilution of isopropyl alcohol and distilled water swished around inside the headlight will cure the condensation problem. it is important that you do not go above 50% alcohol because it could potentially damage the lenses. you will have to remove the headlamp assemblies to do this.
06 Touring Edition NA/Auto. Airaid intake, Magnaflow Stainless cat-back exhaust, Taylor Thundervolt plug wires, rear lowered 1.75" with H&R Springs. Yep, buying parts I cant afford with money I dont have to impress people I dont like anyways. |
Thanks, both of you. I'll try the alcohol. Couldn't hurt.
Check the wheel well, I had the same problem. The wheel well was a little loose, I just shoved it somewhere where it was sturdy and that solved the problem.
My Baby: 01' Taupe Limited PT Cruiser w/ rear spoiler, Drop in K&N Air Filter, Altezza Tail lights, Limo tint all around, blue neon interior, blue LED windshield nozzles, In-dash CD/DVD/Radio made by Jensen, Vent Visors, Chrome Shift Plate, Chrome Antenna Bezel, Chrome Grille inserts, Turbo Catback exhaust, back-up camera, and a system containing 3 MTX 10" subwoofers and an eclipse 1000watt amplifier. Wish List: Aftermarket tires/wheels, turbo! ![]() CUSTOM DECALS FOR YOUR CRUISER! |
| WTB TYC Tail lamp | Dream4 | Classifieds: Want To Buy | 0 | 17 Jan 2008 01:00 pm |
| Moisture in my Headlight | erwinlg | General PT Cruiser Discussions | 2 | 12 Jul 2004 05:49 pm |
