PT Cruiser Forum Car Videos
Custom Wheels
Is it a fuse or wiring?
Old 09 Jun 2008, 12:16 pm
50by30 50by30 is offline
Default Is it a fuse or wiring?
I have a 2003 Cruiser, and recently after returning from a short trip, I noticed that my headlights and power locks were not working. When I try pushing the lock button, I hear a clicking under the dash (which leads me to believe there isn't a fuse blown.) I checked all fuses, and didn't see any obviously blown.
Does anyone know of this issue? It only seems to have affected my headlights and my locks. Locks, not a big deal, but headlights a bit more. Can't drive near or after dark.
Any help would be most appreciated.
Thanks,
Patrick
Old 09 Jun 2008, 12:40 pm
CREWZIN CREWZIN is offline
Default Re: Is it a fuse or wiring?
Patrick,
Welcome to the forum. You have an unusual situation. The door locks are controlled by the RKEM (Remote Keyless Entry Module) located in the middle of the dash behind the air vents but it has nothing to do with the headlights. Headlight and fog light problems usually turn out to be the multi-function switch on the steering column.
As far as the fuses go, on the inside fuse box both the #3 and #10 fuse say "RKE" so you might what to double check them and the number #19 is for the right headlight, #20 for the left.
2000 PT. 96K miles, Original Owner
Old 09 Jun 2008, 02:44 pm
Thanks...I'm open to others suggestions as well, but do you recommend this be looked at by my local repair guy, or should this be directed to a dealership/authorized service center?
Old 09 Jun 2008, 03:02 pm
I suppose you want the truth. I doubt that you'd find more than a handful of people on this forum that would ever recommend the dealer for service. If you have used your particular dealer before, and they seem to be up front and honest, then try then again, although the hourly rate is bound to be cheaper elsewhere.
Old 09 Jun 2008, 09:59 pm
soonercruiser's Avatar
soonercruiser soonercruiser is offline
Cool Re: Is it a fuse or wiring?
But.......the answer to your original questions is "YES".
Frank, aka SOONERCRUISER, and the Black Sheep
(Two Cruisers are better than one!)
vB code is On
Ignition Off Draw (IOD) Fuse Effects and Replacement Hints ObiMatt87 Tech & Performance Forum 5 04 Aug 2008 11:04 pm
Ignition Hot Fuse Under Hood? brymck Sound and Security Forum 3 03 Jan 2008 09:14 pm
Fog Light Fuse SuperTroy Exterior Accessories Forum 1 17 Aug 2007 06:50 am
Fog Light Fuse bkarr Exterior Accessories Forum 3 15 Apr 2007 08:43 am
Autometer gauges PTGT Redman Turbo Performance 12 23 Jul 2003 09:08 am
Archive: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44
  book restaurant online | Cheap Car Insurance | 2006 Fantasy Football | Payday Loan | Bad Credit Loan
