Wet traction
Old 25 Jun 2008, 11:50 pm
Default Wet traction
New here - sorry if this has been covered. I have a 2006 Limited, no ABS, original Eagle LS tires under 20K miles. Car skids straight line when it is even a little wet, even under light braking, scary!!! Any thoughts?
Old 26 Jun 2008, 05:29 am
Default Re: Wet traction
Welcome to the forum.
At least it's skidding in a straight line. About the only thing you can do is buy better tires. Tires that are made for wet weather.
2000 PT. 100,000 miles, Original Owner
Old 26 Jun 2008, 08:11 am
Without filling in your bio, we have to try and guess where you are located so we may be able to give you good suggestions.
I had a 2006, NA with the stock Eagle tires, drove here in Florida(the Lightning Capital with many summer thunderstorms) and didn't have any trouble with the skidding. Do you still have good tread? Have you rotated tires at least every 5000 miles? Are they worn unevenly? Good Luck???
2008 Silver Steel Metallic, Touring, NA, Sirius; Chromed door handles; lower grille; fog light surrounds; chrome front & rear bumpers strips; Airaid air filter; Bassani duals; Modesty Cover; Autolite AP5263 Platinum Plugs (.040); Crane Plug Wires; NAPA Ceramic pads; Blane hood struts; PTeazer Gas, Brake & Foot Rest Pedals, '05 Rear Step Pad, Stainless Door Sills, Llumar tint, "A" Piller chrome
Old 26 Jun 2008, 02:00 pm
Car is in Columbia, SC - Limited with 205/55/R16 alloys - bought used with 5000 miles, tires maintained and rotated - Never had good wet traction - hydroplanes like crazy. Are the stock Eagles just lousy tires or am I missing something? I would appreciate any comments/suggestions on new rubber!
Old 26 Jun 2008, 02:58 pm
ucantcme's Avatar
Send a message via AIM to ucantcme Send a message via MSN to ucantcme Send a message via Skype™ to ucantcme
My car will hydroplane even in the smallest of puddles and my tires are rated really high for water.
Kinda scary, but I'm used to it.
My Baby:
01' Taupe Limited PT Cruiser w/ rear spoiler, Drop in K&N Air Filter, Limo tint all around, blue neon interior, blue LED windshield nozzles,
In-dash CD/DVD/Radio made by Jensen, Vent Visors, Chrome Antenna Bezel, Chrome Grille inserts, Dual Catback Exhaust, Scan Gauge II,
back-up camera, and a system containing 2 Lanzar 15" subwoofers and an MA Audio 1800watt amplifier.
Check me out on Car Domain!
Old 26 Jun 2008, 04:30 pm
It would be a good idea to check to see if all four brakes are working right. My car tends to go sideways as all four tires lock at once. That might not sound desirable, but you just momentarily let off and then correct and it's all good. No ABS stops MUCH better when you've learned it.
I'd recommend driving on gravel or something that you can skid on easily and lock your wheels. You should see both the front and rears skidding. If only the fronts are stopping you won't have as much stopping power. I'm not sure how much the rear brakes, but probably about 30%.
If the front locks and the rear doesn't the car goes straight.
If the rears lock and the fronts don't the car will try to swing around.
If all four tires lock at the same time the car will go straight unless one wheel has traction, then it will swing in that direction.
If your brakes work fine then your tires suck. It could be that they've just gotten hard even if they still have good tread. I ran had new Uniroyal Tigerpaw tires on the car when I bought it. They had no traction in water and snow, lots of flats, and worn out at 17500 miles. I'm running Cooper Trendsetter SE's right now. They hydroplane a bit but have great traction in water or snow.
Ben
2001 Red PT Cruiser Limited, 16" OEM alloys, Heart Throb dual exhaust, Airaid CAI, Screamin' Demon coil and Livewires, some shiny stuff inside, Alpine deck, Alpine four channel amp, Alpine PLT5 sub, Hertz speakers in 4 corners, new stone chips every day to add character.
2007 Suzuki King Quad 700 4x4 for when the road gets bumpy.
Old 27 Jun 2008, 02:19 pm
PTmodrod's Avatar
Wow... I thought ABS was standard... Mine has it and I have to say that with the amount of tire I have and the new brakes, It is scary how fast it stops, even in the wet. Ben is right about non ABS cars stopping better IF you know how to do it. I was thinking about disabling mine, but I realized that in an emergency I would rather have it.
01, Inferno Red, PT LE, 5-speed Manual.
EXT:American Racing Casino wheels, Intrax Lowering Springs, California Cruisers Shark front and rear rollpan, red lighting
INT:Hurst Short Throw Shifter, Factory 8in rear sub, red footwell lighting, In-dash radar detector, Starter button, custom switches
PERF:OBX Tube Header, ECC High Flow Cat, Borla Dual Cat-back Exhaust, Drilled and slotted rotors and performance pads
Custom Decals From Metro Car Design
Pictures of my PT
http://www.banfielddesign.com
Old 27 Jun 2008, 10:38 pm
I think the stock Good-for-a-Years suck. I've lowered the car, put in rear sway bar, and best handling thing I did was the tires.
I got Michelin Hydroedge - much better in rain, handle, and are really wearing well.
In the meantime, check you tire pressure - go a couple psi above the # on the sticker inside the driver's door.
Old 27 Jun 2008, 11:10 pm
ucantcme's Avatar
How would you not know how to stop a car with no ABS? Just pressing the brake enough right before it's at the lock up level? My car doesn't have ABS and I love it, lol.
My Baby:
Old 28 Jun 2008, 12:08 am
ABS is more drivable in a panic situation. It won't make the car go sideways due to wheel lock and it lets you steer when braking. In a panic situation that can be the difference between crashing and not crashing. However when you learn how to control the brakes you can use that to your advantage. One thing I often do in winter if I've come up to an icy intersection too fast is to lock the brakes, car goes in straight line, crank the wheel full lock, and when I'm up to the turn release the brake. This allows you to have the brakes applied longer and still be able to make the corner.
The main thing to keep in mind with no ABS is that if it's not doing what you want, let go of the brake for a split second.
There are people out there that don't know how to drive without ABS, that's why it was invented.
Ben
ABS TRACTION WARNING LIGHTS javaman Tech & Performance Forum 2 12 May 2005 09:34 am
Psi-Fi Traction Bushings ksquared11 Vendors & Buyers Forum 0 29 Oct 2004 07:00 pm
Traction Control peppy General Turbo Discussions 2 06 Jun 2004 06:35 pm
PT Cruisers, winter driving, and traction control Quadrajet General PT Cruiser Discussions 9 12 May 2004 02:39 pm
traction control noise??? mine doesn't do it! pingber General PT Cruiser Discussions 7 13 Jan 2003 11:18 am
  Debt Consolidation | Myspace Images | Wordpress Theme | Debt Consolidation | Lil Wayne
