Fan not coming on
Old 04 Jul 2008, 09:47 pm
Default Fan not coming on
My pt overheats only when it is sitting still or not going over 40km/hr. I cannot hear the fan kicking on at all. Is there a fuse somewhere for that? just before this started happening, like 30 mins before, I had to boost the car because the lights were left on long enough to kill my old battery. when i started to boost it i went right off the battery then the cables were smoking so i switched over to that boost post....i think this did it to me....anyone ?
Old 04 Jul 2008, 11:03 pm
Default Re: Fan not coming on
after researching i have found that there are relays for the fan...is it possible that I blew one of these by incorrectly boosting my battery?
Old 05 Jul 2008, 06:17 am
It's possible you blew one or both of the fan relays or there's a separate fuse for the fan also. In order to help more, we need some more information about you cruiser, especially the year. Do you have an owners manual?
2000 PT. 100,000 miles, Original Owner
Old 05 Jul 2008, 07:10 am
It is a 2002 limited edition,with about 159k. i have the manual. I found the relays for highspeed and low. Where is that fuse though?
I am off to the parts store today at noon to buy a relay, unless there is a way to test it.
thanks for all the help.
Old 05 Jul 2008, 07:43 am
OK, the picture below is what the fuse box looks like in the engine compartment (only it's 180 degree backwards). The Number #5 fuse (40 amp) is for the fan.
All the square relays (A thru F) are the same type so you can use the Horn relay to test the High Speed fan relay but there's no other relay like the Low Speed Relay to check that out.
Most people that had the fan stop working found out that the fan motor itself was burnt out, not the fuse or relays.
If your a do-it-yourself type, you can jack the front of the car up and check out the fan motor by pulling apart the electrical connection to the fan and applying a hot and negative wire to the fan to see if it comes on. If not, it's probably the fan motor that is bad. You can see the fan electrical connection in the picture below. You push the red tab at the top of the connection to the right to be able to disconnect it.
Old 05 Jul 2008, 08:14 am
Crewzin, you are a wealth of information!!
2008 Silver Steel Metallic, Touring, NA, Sirius; Chromed door handles; lower grille; fog light surrounds; chrome front & rear bumpers strips; Airaid air filter; Bassani duals; Modesty Cover; Autolite AP5263 Platinum Plugs (.040); Crane Plug Wires; NAPA Ceramic pads; Blane hood struts; PTeazer Gas, Brake & Foot Rest Pedals, '05 Rear Step Pad, Stainless Door Sills, Llumar tint, "A" Piller chrome
Old 05 Jul 2008, 08:21 am
Ernie,
You know that 95% of the questions asked are ones we've seen before. I have the Haynes manual for the pictures plus I've run into some of the problems myself so I keep a file stuffed full of helpful pictures in Photobucket and as I said, for information, we've run into most of this stuff before.
What I do need is a picture of the new fuse compartment from the 06-08 cruisers with information as to what all the 37 fuses are for. As you know they no longer have the interior fuses on the new models. I'll have to get a hold of a new owners manual.
Old 05 Jul 2008, 12:11 pm
I can take a hint, I'll try to send the info to you.
Old 05 Jul 2008, 01:48 pm
Got em. Thanks!
Old 05 Jul 2008, 04:40 pm
aha, the fan only works when the ac is on! what does that mean? sensor?
thank you
any changes coming in the 08 pt ?? bobs turbo pt General PT Cruiser Discussions 7 01 Jul 2007 05:36 am
Fluid coming out of exhaust... crazie.eddie General PT Cruiser Discussions 10 11 Nov 2004 04:21 pm
Block party coming turbomangt Midwest PT Forum 1 15 Sep 2004 04:45 pm
CruiserMania is coming to Arizona THISLPT Western PT Forum 3 01 Oct 2003 11:31 pm
Spoiler coming loose turbomangt Exterior & Interior Styling 2 26 Aug 2003 10:19 pm
  Find jobs | Wordpress Themes | Debt Consolidation | Web Hosting | Watch Naruto Online
