Rear driver's side door will not open at all!
  #11 (permalink)
Old 05 Aug 2008, 09:49 am
Default Re: Rear driver's side door will not open at all!
Hey Candyman
I'm in Los Angeles. Hemet is sorta kinda over there past Riverside I think..I went to UCR hehe. But cool any tips are greatly appreciated
  #12 (permalink)
Old 05 Aug 2008, 12:54 pm
Candyman's Avatar
Smile Re: Rear driver's side door will not open at all!
Hey Greeen,
Yep! I am out off the 215 by March Air Force Base just past Riverside. I will shoot over a message to a few of my Mechanical buddy's over their, and should here back in a couple of days at the latest! Ill let ya know as soon as they get back to me 4 sure!
Candyman
  #13 (permalink)
Old 04 Oct 2008, 10:07 pm
Talking Re: Rear driver's side door will not open at all!
I just fixed this same problem today with the 2 back doors on my 2003 PT. The reason this happened is because I never lubricated the latches within the door jams. What I did to correct this was to remove the rear seat, then remove the inner door panels with the windows up. Once the panel was off I removed the inner window track so I could see the mechanism clearly with a trouble light. I then squirted WD40 all over it then worked the rods back and forth and kept pushing the button on the door handle from the outside. After a short time of working these the door opened right up. With the door opened I then wire brushed the corrosion off the U shaped hook opposite the latch and further lubed the latch with more WD40 then greased it and worked the latch back and forth with a scew driver making sure it moved freely. The doors open and close fine now and I didn't need a new latch assembly. The tools needed are a phillips head screw driver, a Torx driver and/or 10mm socket to get the arm rest off and the 2 bolts holding the window track in plus my fingers to pry off the panel. The whole job was pretty easy and didn't take much time all.
  #14 (permalink)
Old 05 Oct 2008, 03:39 am
oldcoach's Avatar
I know what I have to do today. Put a little white lube on the door latches.
02' Black Woodie Limited Edition Drop in K&N Air Filter w/air box mod. 06 tail lights, Limo tint all around, orange LED interior, Mopar 8 inch sub, Stull side pipes. Silver stars upfront, a little chrome
  #15 (permalink)
Old 07 Oct 2008, 09:08 am
Thanks for the advice Mike i will give it a try.
  #16 (permalink)
Old 07 Oct 2008, 11:19 am
Teekypt's Avatar
Send a message via Skype™ to Teekypt
Exactly!!! I plan to do the same!
2003, GT, "ShuggaPlum", xenon bumper kit and Accra-Form Running Boards, custom tan/black neoprene seat covers (front & back).
Houston, TX
http://www.math.uh.edu/~tai/Today/Clean3.jpg
  #17 (permalink)
Old 17 Jun 2009, 10:20 pm
I have the same problem with my 2007 - the rear passenger side door was fine - then all of a sudden it won't open from the inside or the outside. It's not locked - I can pull the door a little away from the frame, but can't figure out what is wrong it. Did anyone ever solve this problem? I have an extended warranty, but don't really want to spend $100 to have the dealer fix it.
  #18 (permalink)
Old 18 Jun 2009, 06:52 am
Originally Posted by minnginn View Post
I have the same problem with my 2007 - Did anyone ever solve this problem?
Did you not just read CoolhandMike's reply ? Wouldn't that solve your problem?
  #19 (permalink)
Old 18 Jun 2009, 07:07 am
Actually, I had not seen it as I had only looked at the first page of the responses, but my door locks and unlocks, so can it still be the latch? Sorry - I don't know a lot about cars or how the door mechanisms actually work.
  #20 (permalink)
Old 18 Jun 2009, 07:11 am
Well, if you don't want to spend the $100 for the warranty, looks like you'll have to do the same as CoolhandMike and take the inside door panel off to find out what's making yours not open.
Rear driver's side storage area question jackfrisch General PT Cruiser Discussions 19 24 Aug 2011 04:42 am
Rear pass. side seat need help hoppyloop Interior Accessories Forum 0 11 Apr 2008 12:59 pm
Driver Side Rear rattle or squeek Imdaddog PT Cruiser Convertible Forum 1 28 Nov 2007 01:06 pm
Pop the rear hatch open using the remote zapwizard Exterior Accessories Forum 4 28 Jun 2007 08:32 pm
Rear Hatch Open light stay on? KingKole02 Tech & Performance Forum 5 13 Jul 2004 01:25 pm
