Story of my life with automobiles. Something breaks repeatedly, I pay mechanics over and over to "fix" it and they never do.
The story for my PT Cruiser is as follows. One day a few months back I was driving home and my transmission seemed to jump as I was accelerating, probably when it was about to shift gears. After that my engine light went on and the car would not go higher than 3rd gear. After turning it off and back on, the car ran perfectly fine, but the engine light remained on. The code was 0700 which I found out here is a general transmission issue. So I brought the car in and they said they couldn't find anything wrong with the transmission, but they called Chrysler and were told that what was happening is often a problem with the filter. So $200 and a new filter later, they said it was fixed. So I drove around for a few weeks or so without a problem, then OF COURSE the same exact thing happens all over again. This time I am in another city so I have to bring it to some random mechanics I'm not familiar with. I explain the situation to them and about how I already had it "fixed" but it didn't work out. They take a long look at it and decide its most likely some loose wiring they found. Bam, $200 later and it's "fixed" for the second time. Now another few weeks later I was just driving it and surprise surprise, it happened AGAIN. As usual when I shut it off and on it works fine. I am so discouraged that I don't even want to bring it in again and waste more money. Would it be dumb of me to just ignore it until something actually breaks? I don't know what to do anymore, I am so fed up with cars and mechanics. Does anyone know how to make the engine light shut back off? What would you do in my situation? Thanks! |
Thanks for your help. |
hi, cant you bring it back and say listen you didnt fix the problem ?? and wot is wide open throttle
Before you get rid of the light, a question. Did either shop hook up your PT to a scanner? Yes, the P0700 code is generic but a scanner should be able to narrow down the cause of the code.
There's been lots of problems with the solenoid pack of the tranny. My sons mother-in-law just had hers replaced on her 2002 and others on this forum have had the same issues. One of the Master Mechanics on this forum replied to the issue like this: ------------------------------------------------------------------------------------------------- P0700 only means there are transmission control module codes to be read with a scanner. The TCM codes will explain more of the fault information. The TCM cannot trigger the light, only emmisions related faults can trigger the light. So,.... they program a generic code to tell the PCM that there is a fault. P0700 is the TCM code for the PCM. You may have one or many TCM codes to be read. -------------------------------------------------------------------------------------------------- By the way, reading this can be frustrating without this: ECM = Engine Control Module PCM = Power Control Module TCM/U = Transmission Control Module/Unit ECU = Electronic Control Unit CEL = Check Engine Light
![]() ...just CREWZIN along! ® . . . PT Cruiser Links Moderator ![]() 2000 PT. Original Owner, 110,000 miles MY technical suggestions are given in GOOD FAITH without total guarantee, if in doubt go to a Garage. Visit My Home Page www.CREWZIN.com Last edited by CREWZIN; 23 Jul 2008 at 06:41 am. |
I wonder if it still is under warranty? Yes, I know it is a 2001, but it is still under 50,000 miles. If I remember right, didn't they have a 5 year (over)/ 50,000 mile warranty. Have you taken it to a dealer?? Give it a try, you have spent mucho dollars already with no fix.
![]() 2008 Silver Steel Metallic, Touring, NA, Sirius; Chromed door handles; lower grille; fog light surrounds; chrome front & rear bumpers strips; Airaid air filter; Bassani duals; Modesty Cover; Autolite AP5263 Platinum Plugs (.040); Crane Plug Wires; NAPA Ceramic pads; Blane hood struts; PTeazer Gas, Brake & Foot Rest Pedals, '05 Rear Step Pad, Stainless Door Sills, Llumar tint, "A" Piller chrome; APC Strut Bar |
Crewzin, yes both places scanned it for the transmission codes. I can't remember exactly what the first place said, but at first they thought it was something MAJOR because of the codes (maybe broken cylinder?). But once they took it apart they found nothing wrong, so that's why they called chrysler.
I do have it under a major mechanical warranty but they're sticklers about what they approve repair for. It pretty much has to be something major and not my fault. |
Don't know what else to tell you. I don't see how any of this could be your fault so hopefully you'll find an answer and the warranty will cover it.
Weird, the engine light went off on it's own 2 days later. What does that mean?
That is normal. If the problem that set the engine light on goes away, after several starts the check engine light will go off. Only if problem is still there will check engine light stay on after several restarts of the car. It means that whatever problem you have, it isn't a "solid" problem, but intermittent.
