PT Cruiser Forum Car Videos
Custom Wheels
A/C issue.
Old 25 Jul 2008, 08:38 pm
hermtm2 hermtm2 is offline
Default A/C issue.
Hi.
My sister has 02 PT which is 110k on it. She haven't driven the car for a while because she just back to the travel. When the A/C was on today, it didn't blow any cold air at all. It was working before she went to. We drove the car about 1 hour and then tried again. There were only normal temperature air not the cold. I tried to charge A/C gas on the system. When I checked the low pressure hose, it showed me 100 psi. What's wrong? How can I fix the A/C problem?
Thanks.
Old 25 Jul 2008, 08:58 pm
CREWZIN CREWZIN is offline
Default Re: A/C issue.
Is the compressor coming on when you turn on the AC? Is the fan coming on when you turn on the AC.
On a Google search of low pressure settings for Chrysler vehicles, your 100 psi is way to high. The pressure sensor is probably turning off the compressor.
2000 PT. 96K miles, Original Owner
Old 25 Jul 2008, 09:29 pm
Hi.
How do I know the compressor is working or not? I tried to search "low pressure settings for Chrysler vehicles" but nothing.
Thanks.
Old 25 Jul 2008, 09:41 pm
Google "Chrysler AC pressure on low side".
With the AC on and motor running at idle, the engine RPM should raise and lower a little each time the compressor turns on and off.
Old 26 Jul 2008, 12:31 am
ucantcme's Avatar
ucantcme ucantcme is offline
Send a message via AIM to ucantcme Send a message via MSN to ucantcme Send a message via Skype™ to ucantcme
Is it just me, or is it everytime I turn on my A/C (Hot days 95+) my car runs like crap.. Seems like my car is bogging whenever I run the A/C. Getting up to speed on the interstate with the A/C on is quite the task for the PT to handle.
Anyone?
My Baby:
01' Taupe Limited PT Cruiser w/ rear spoiler, Drop in K&N Air Filter, Limo tint all around, blue neon interior, blue LED windshield nozzles,
In-dash CD/DVD/Radio made by Jensen, Vent Visors, Chrome Antenna Bezel, Chrome Grille inserts, Dual Catback Exhaust, Scan Gauge II,
back-up camera, and a system containing 2 Lanzar 15" subwoofers and an MA Audio 1800watt amplifier.
Check me out on Car Domain!
Old 26 Jul 2008, 06:30 am
It's not right Ron. I can't tell weather the AC is on or off as far as the engine performance. It should only sap about 3-5hp and you shouldn't be able to tell the difference. If the problem was at idle I'd say check the IAC but your's is a different problem.
Old 26 Jul 2008, 06:34 am
bobs turbo pt bobs turbo pt is offline
i agree see if the compressor is coming on and check the 100 psi reading again
Old 26 Jul 2008, 05:20 pm
ucantcme's Avatar
Thanks for the response....How about if I added that there is sometimes a little whistle that only happens while pressing the gas with the AC on.
My Baby:
Old 26 Jul 2008, 05:49 pm
Have you actually tested it and listened for the whistle without the AC on? A whistle would sometimes mean air sucking in which translate to a vacuum leak but it would happen with or without the AC.
Old 26 Jul 2008, 08:40 pm
ucantcme's Avatar
The whistle is only when the AC is on and the gas pedal is being pressed. It might be continous without the gas pedal, but I only notice it w/ the gas being pressed...
My Baby:
vB code is On
Weird issue Opiate General PT Cruiser Discussions 4 09 Aug 2008 10:05 pm
PT Cruiser Issue banddork123 Tech & Performance Forum 3 22 Jun 2008 07:17 pm
Rear hatch latch issue oldcoach General PT Cruiser Discussions 0 30 Jul 2007 10:00 am
CARB issue resolved? tezz Stage Turbo Kits 19 20 Aug 2003 03:37 am
A Few Thoughts On The Mopar Issue Steve03GT Turbo Performance 10 12 Jun 2003 05:36 pm
Archive: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44
  Credit Reports | Shares | Cheap Loan | Loans | Homes for Sale
