Can I get some Help??
Old 05 Aug 2008, 08:08 pm
turbo_pt2003's Avatar
Default Can I get some Help??
I found a cooling fan assem. on E bay and Its says its for a 2004-05 pt turbo, and mine is a 2003 turbo model. does anyone know if their compatable, or where i can find if the part number is the same?
Old 05 Aug 2008, 08:16 pm
Default Re: Can I get some Help??
They should all be the same from 2001 to 2005. Make sure the one your buying is new and the price should be somewhere around $100 without shipping.
Old 05 Aug 2008, 08:49 pm
Turbo PTs use a variable speed fan controlled by the PCM.
The non-turbo uses the 2-speed fan with relays to control them.
They are not interchangeable.
Although I've changed over a dozen 2-speed fan assemblies, not one single turbo fan has failed in the 60 or so PTs I service.
Old 05 Aug 2008, 09:29 pm
The fan has'ent failed... I have. lol it was broke along with the radiator when i went into a ditch
Old 05 Aug 2008, 10:00 pm
Thanks for the info (Mike) MX-5. I've taken a look at half a dozen sites and they all say 01-05 cruisers never asking if it was a turbo or not in the ad.
Old 06 Aug 2008, 08:58 pm
Crewzin do u honestly think that if I buy this item that it would work? Or does any one else have any info on it, I understand that the turbo and non turbo models may not be interchangeable but being that mine is a 03 turbo and the part im looking at is for a 04-05 turbo so their both turbo's... I cant find anything on it thanks guys, Daniel
Old 06 Aug 2008, 09:14 pm
I don't know why 04-05 would be different than 03 but you never know. I certainly believe Mike when he said Turbo's are different than the non-turbo's as Mike works on these cars everyday. Can you contact the seller of the eBay fan and ask why his are for the 04-05 only?
Unless Mike gets back to this thread and tells us if the 03 is different than 04-05, that's all yo can do.
Old 07 Aug 2008, 06:34 am
Originally Posted by CREWZIN View Post
if the 03 is different than 04-05.
I can't tell you, because I've never had to replace a turbo PT fan module.
Your Chrysler dealer parts man can give you the part numbers and you can match them to the E-bay guy.
I get my replacement parts from Chrysler.
