Oil Cunsumption
Old 09 Aug 2008, 05:25 pm
Cool Oil Cunsumption
I have a 2001 PT with 68,000 miles. For the last year it has been consuming 1 qt. of oil per 1500 miles. It is now using 1qt. per 1000 miles. I have replaced the PCV valve last week and there was no oil on it when removed. There are no oil leaks nor any smoke. Anyone famaliar with this problem?
Old 09 Aug 2008, 06:15 pm
Default Re: Oil Cunsumption
Only thing I can think of is a very small crack in the head gasket. or a bad piston ring. A very tiny use of oil into the mainstream won't leave the tell-tale smoke out the exhaust.
Found on the internet........
It will tell you if your engine has good compression. An engine is essentially a self-powered air pump, so it needs good compression to run efficiently, cleanly and to start easily.
As a rule, most engines should have 140 to 160 lbs. of cranking compression with no more than 10% difference between any of the cylinders.
Low compression in one cylinder usually indicates a bad exhaust valve. Low compression in two adjacent cylinders typically means you have a bad head gasket. Low compression in all cylinders would tell you the rings and cylinders are worn and the engine needs to be overhauled.
