Alright, I thought the PT's had a 15 gallon gas tank. The fill up before my last, I pumped in 15.6 gallons. Today I pumped and it took me 15.2 gallons.
Now after the 15.6 gallon fill up, my gauge didn't read full completely. Today when I pumped 15.2 gallons it read full...as it should. Any thoughts??
My Baby: 01' Taupe Limited PT Cruiser w/ rear spoiler, Drop in K&N Air Filter, Limo tint all around, blue neon interior, blue LED windshield nozzles, In-dash CD/DVD/Radio made by Jensen, Vent Visors, Chrome Antenna Bezel, Chrome Grille inserts, Dual Catback Exhaust, Scan Gauge II, back-up camera, and a system containing 2 Lanzar 15" subwoofers and an MA Audio 1800watt amplifier. Check me out on Car Domain! |
Ron,
First let me start off by saying that by letting the fuel get so low, your eventually going to burn out your fuel pump, about a $300 fix. The fuel not only cools but lubricates the pump and by letting the tank get so low, your running the pump dry, not only that, but any sediment that might get into the tank goes to the bottom and by letting it get that low you could suck it up into the system. MX-5 (local Master Tech) has repeatedly said that he's changed out quite a few fuel pumps when they burnt out. The owners manual says that the tank holds 15 gallons. You've already found out it holds a little more, but not much more. The lines, filler nozzle and fudge factor probably gives you another 1/2 to 1 gallon.
![]() ...just CREWZIN along! ® . . . PT Cruiser Links Moderator ![]() 2000 PT. 96K miles, Original Owner Visit My Home Page www.CREWZIN.com |
Thanks, Carey. I wish I could have a visual reference of how much fuel (in gallons) I have in my tank. The ScanGuage does that I believe...I will be investing in one of those in the near future.
Um, what?
Bad engineering leading to fuel pump failure, and that's ok with Chrysler? Awesome. Or is there some recall to fix this issue? Ucantcme, how about filling to the top of the filler neck (gently, and carefully) to make sure you reach the same point each time? I do that so that my mileage recording/tracking is as consistent as I can get it.
Maybe. Maybe not. |
I fill it up until there is gas that sits in the "neck" of the gas tank.
I don't make em. I just pass on the information that I know or have seen on this and other PT Forums. There's been, I think, 3 recalls and one for the gas tank but not because of the pumps that burn out.
I don't think he was blaming you for anything...Just saying Chrysler did a....less than perfect job with the fuel pump.
The scan gauge does tell how many gallons of gas are left. You will find that filling up at different times of the day will give different volumes. It's best to fill up in the morning when it is cooler.
\'05 Stone White SRT4 \'04 Graphite PT Automatic |
Im confused.
| Vaccuum Tank?? | notadodge | Tech & Performance Forum | 5 | 09 Mar 2008 11:27 am |
| Is it ok to add fuel injector cleaner to gas tank? | Mary | General Turbo Discussions | 7 | 20 Jan 2008 10:45 pm |
| Gas tank leak | asaccoma | General Turbo Discussions | 7 | 26 Dec 2007 09:54 pm |
| Gas Tank | BruisersCruiser | General PT Cruiser Discussions | 5 | 14 May 2004 04:42 pm |
| who is going to be in the Dunk Tank at CTH | KC cruizin | General PT Cruiser Discussions | 0 | 25 Mar 2002 06:10 pm |
