How to increase gas mileage in the PT
Old 24 Aug 2008, 03:44 pm
ucantcme's Avatar
Send a message via AIM to ucantcme Send a message via MSN to ucantcme Send a message via Skype™ to ucantcme
Default How to increase gas mileage in the PT
This post is intended to help, or otherwise inform people out there of a website that has helped me increase my Fuel Economy in my 2001 Limited PT Cruiser.
Join GasSavers.org - Fuel Efficiency, Save Gas and Gas Mileage Forum
Join their forums, and read up on how people are increasing their fuel economy in the weirdest, most simplest ways. I'm used to getting <20MPG, as soon as I took a night to read through the forums, gather some ideas...I filled up my tank and started to use some of the techniques mentioned.
As I said, getting less than 20mpg was normal for me as the kind of driver I am. My last fill up proved that just driving a few miles per hour slower, and using the brakes less CAN and WILL increase your fuel economy. I got 24.99MPG on my last fill up.
On that site, you can create your own gaslog and keep track of your miles per gallon as long as you input the numbers in the form provided.
I hope you found this helpful.
My Baby:
01' Taupe Limited PT Cruiser w/ rear spoiler, Drop in K&N Air Filter, Limo tint all around, blue neon interior, blue LED windshield nozzles,
In-dash CD/DVD/Radio made by Jensen, Vent Visors, Chrome Antenna Bezel, Chrome Grille inserts, Dual Catback Exhaust, Scan Gauge II,
back-up camera, and a system containing 2 Lanzar 15" subwoofers and an MA Audio 1800watt amplifier.
Check me out on Car Domain!
Old 24 Aug 2008, 05:27 pm
Default Re: How to increase gas mileage in the PT
For what it's worth, I have higher pressure tires on my car and am running them at 50psi.
In another thread, there were questions about handling on "hard" tires, and after driving on these tires for 6 months, I've found no handling issues at all.
Higher tire pressure makes your tire "rounder" and so you are not continuously trying to drive "uphill" as much over the tiny flat spot at the front of tires that are at lower pressures.
Maybe. Maybe not.
Old 24 Aug 2008, 05:31 pm
ucantcme's Avatar
Isn't less of your tire on the road though?
My Baby:
Old 24 Aug 2008, 05:43 pm
Driving on 50 psi is not good for the tires. They'll wear funny and are more prone to blowouts. It may say 50 psi is the max on your tires, but my tire shop said that means only if you are carrying a lot more weight in your vehicle. At 50 psi under normal car weight you'll have less traction and are more apt to hydroplane in the rain. Better drive careful.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Mileage? jr_shadetree Tech & Performance Forum 10 21 May 2008 07:49 pm
2006 PT Limited Ed Mileage is terrible. vetteloverpa General PT Cruiser Discussions 45 11 Mar 2008 12:09 am
Gas Mileage for you NA PT Cruiser matt87951 Tech & Performance Forum 7 16 Mar 2004 01:17 pm
HP increase With Diferent Items Ian-PT-GT Turbo Performance 22 29 Jul 2003 11:39 pm
Engine heating up, mileage and tires need inflatio rleung96b Tech & Performance Forum 2 14 Jan 2003 01:05 pm
