Air Bag Light
Old 31 Aug 2008, 10:21 am
Default Air Bag Light
Hello...first post...interesting site. My air bag light is on, the horn does not work and the cruise control does not work. Looking through previous posts it seems that the clock spring is causing this. I recently had a second hand steering column fitted (as Chrysler wanted 1000) as a small part on the column happened to be corroded...could not buy that part, had to buy the whole column. Can anyone tell me what a clock spring is...what it looks like and can I buy one? or do I just roll on without it all working. I love my PT (its a 2000 PT Limited) and would early love it to be right..and my wallet would like to avoid the dealer!
Old 31 Aug 2008, 11:59 am
Default Re: Air Bag Light
Welcome to the forum. Hopefully someone will come along with more knowledge of the clockspring workings than I have. I can give you a couple pictures to help you out that way.
I can tell you that the book says you have to disable the airbag before doing anything. Figure 16.3 tells you how.
Then the airbag comes out and you should be able to see the clockspring mounting details, Figure 16.8
Old 01 Sep 2008, 01:32 am
what happened is that the column was not correctly centered before installation, causing you to snap the ribbon in the clock spring when you turned a corner. you should have gently turned the wheel all the way one way till you felt slight resistance, then turned it the other way and counted the revolutions till you feel resistance again. divide that number by two, turn the wheel that many turns and locked it in that position. this way the clock spring is centered. new clock springs come locked in the center position from the factory. when replacing, center the steering wheel and wheels, then lock in that position. remove neg. battery terminal and wait for 10 minutes. remove airbag and steering wheel. then you can access the clock spring. remove the old one, install the new one, then remove the locking tab that holds the new clockspring centered. install the steering wheel then airbag. reconnect battery. take to someone with a airbag scan tool to have codes cleared and check for proper operation. pretty straight forward operation.
06 Touring Edition NA/Auto. Airaid intake, Magnaflow Stainless cat-back exhaust, Taylor Thundervolt plug wires, rear lowered 1.75" with H&R Springs.
Yep, buying parts I cant afford with money I dont have to impress people I dont like anyways.
Old 01 Sep 2008, 08:58 am
my wifes 04 air bag light comes on and there is a chime then goes off not sure what is going on there ?? any thoughts ?? everything else works horn, etc, etc,
Old 01 Sep 2008, 11:40 pm
Does it happen when you first start the car only, or is it happening while you drive?
Old 01 Sep 2008, 11:47 pm
ucantcme's Avatar
Send a message via AIM to ucantcme Send a message via MSN to ucantcme Send a message via Skype™ to ucantcme
Usually when you start the car, it'll chime a few times with all the engine lights on....I think the Chime # was 7?? I forgot, but those lights ARE supposed to go on for a test when you start the car.
My Baby:
01' Taupe Limited PT Cruiser w/ rear spoiler, Drop in K&N Air Filter, Limo tint all around, blue neon interior, blue LED windshield nozzles,
In-dash CD/DVD/Radio made by Jensen, Vent Visors, Chrome Antenna Bezel, Chrome Grille inserts, Dual Catback Exhaust, Scan Gauge II,
back-up camera, and a system containing 2 Lanzar 15" subwoofers and an MA Audio 1800watt amplifier.
Check me out on Car Domain!
Old 02 Sep 2008, 06:12 am
her car chimes while you are driving sometimes over & over sometimes only a few times really strange
Old 02 Sep 2008, 06:52 pm
see if you can convince someone with a air bag scanner to ride along on a test drive with you while the scanner is hooked up. when it starts chiming, they can scan it to see whats going on. they still might find a past code stored in the module. usually if the light stays on, it means that the air bag module's self test has determined that some part has malfunctioned.
Intermittent oil warning light pt2 sawdust123 General Turbo Discussions 25 03 Apr 2017 07:41 am
Check engine light, skipping ab1 Tech & Performance Forum 2 02 Aug 2008 11:13 pm
LUMINICS head light and fog light bulbs 03baggedturbo Vendors & Buyers Forum 8 22 May 2008 08:36 am
how to hook up a rear floor aux light pppt03turbo Exterior & Interior Styling 4 15 Dec 2005 09:57 am
Reverse light stolen, need a new one. coolvirus Exterior Accessories Forum 5 29 Jun 2003 07:47 pm
