New to the Game
Old 12 Oct 2008, 11:01 pm
Default New to the Game
Hi,
Im new to the forum and also a new owner of a 2001 LE PT Cruiser 5-speed. I was doing great with it and the only repair done so far is replacing the Power Steering Pressure Sensor. I don't have any of the prev owners maint records. Here is where the problem comes in. Two days ago I was sitting idle for maybe 10 to 15 min with my A/C running when I noticed this bubbling or gurgling noise coming from up under the hood. I immediately turned the car off. 15 min later I restarted the car w/no problem. Well today I was out for a little bit and when I was idle at a stop light I heard the noise again. The temp gauge started going up but when I started to drive again the temp went back normal. It did this up down sequence til I got home. Can anyone suggest what the problem may be and if you had this problem tell me what your solution was. I keep seeing threads about the fan but I don't have a owners manual and Im kinda confused about the high and low fans. Can someone explain to me about the differance between the two?
Old 13 Oct 2008, 05:02 am
loxmith's Avatar
Default Re: New to the Game
Sorry I can't help you with some advice about your issue. I sure someone will be along soon that can though...in the mean time welcome.
Old 13 Oct 2008, 09:00 am
Sounds like you have a fan speed problem. Do a search to find out how to check it out. The radiator fan has two speeds and one it shot.
2008 Silver Steel Metallic, Touring, NA, Sirius; Chromed door handles; lower grille; fog light surrounds; chrome front & rear bumpers strips; Airaid air filter; Bassani duals; Modesty Cover; Autolite AP5263 Platinum Plugs (.040); Crane Plug Wires; NAPA Ceramic pads; Blane hood struts; PTeazer Gas, Brake & Foot Rest Pedals, '05 Rear Step Pad, Stainless Door Sills, Llumar tint, "A" Piller chrome
Old 13 Oct 2008, 09:36 am
Hi,
Thanks for the reponses. I actually just got back from a shop and the only thing they can find is that the radiator hose was loose causing a trickle of fluid to be released. He tightened up the clamp on the hose and added more antifreeze and so far so good its working . I will keep a close eye out on it and will keep everyone posted. Thanks again to all who replied.
Old 13 Oct 2008, 02:02 pm
crusierdad76's Avatar
Im kind of new here as well but from what i have read it is most likely a bad fan they seem to be a little bit of a weak spot id get ready to replace it or maybe have it checked out these cars don't like to get to hot
Myrtle Bocce 6 FloweryBranchCruiser Southeast PT Forum 0 15 Oct 2005 06:27 pm
Cool Ping Pong Game IRPT Non-PT Discussions 1 14 Apr 2004 12:08 pm
Train Game IRPT Non-PT Discussions 1 19 Mar 2004 12:11 pm
Another game to past the time at work IRPT Non-PT Discussions 2 10 Mar 2004 11:44 am
a detective game Kruza Non-PT Discussions 0 28 May 2003 04:33 am
  Loans | Debt Consolidation | Online Advertising | Turquoise Rings | Debt Consolidation
