Need a little help on this?
I have a 2007 CDN PT Convertible! We purchased it Sept 1st 18,000. KLM and since then a check engine light picture has showed up under the P for park on the dash 5 times, the car runs great no missing or any ruff idle. The salesman said not to worry as his Sebring does the same thing and as long as it dosen't start flashing it will go out in 72 Hrs? What the heck is that? I called the service Dept about a week ago and they, As the bill at no charge says. Scan PO4567 evap system small leak. Replace NVLD switch as best Guess. Code was already in a stored condition. When I started the car this morning the little engine was back over the P for park again. The service manager told us when he did the scan that if that wont work he dont know what is wrong. Chrysler dealer ?????? Has anyone had this problem and what is it. Thx Guy,s Ron G K Kitchener Ontario Canada rongk@sympatico.ca Last edited by RonDee; 19 Oct 2008 at 11:44 am. |
Since it throws the code PO4567 evap system small leak could it be the gas cap not sealing evap system right.....just a thought and about 10 bucks.
I have tryed to tighten the Gas cap many times and let it click till the cows come home I will ask them to replace it the next phone call Thx for your comment and no $10.00 to you.
P0457 is Loose gas cap. It means that the PCM has seen the fuel level change significantly and the next time it ran the evaporative emissions test it detected a leak. The dealership needs to smoke test the system and see where it is leaking at. Too bad you are in Canada and I'm in Texas otherwise I'd make sure to fix it.
Next time you fuel up try Petro Canada mid-grade, drive for a week and light should go out. If I use co-op gas or shell gas, my engine light comes on.
Thx Guy's
I just printed the page of the question and answer's . Next step is to see my service manager and see if He will take some constructive critisizum? Thx again Ron G K |
I hope you all have your own little OBD II code readers. They are not expensive and you can buy them at most auto stores. First they give you a clue as to what the system is trying to tell you and next you will be armed a little when someone tries to tell you, you must do something when there really is no indication by the system that is the problem. I am not accusing mechanics and dealerships of anything, but this little device can give you a little piece of mind. It has saved me more than once. My truck was running poorly and I took it to a shop. The mechanic wanted $250.00 to fix it. Being an independent kind of guy I got the reader, looked up the code, found out it was the O2 sensor, replaced it for $35.00, saved $215.00, end of story.
2002 Touring Edition --- wife’s purple grocery getter --- Other vehicles BMW Z4 roadster and Mercedes 190E. |
Well Guy's
I called the service Dept this afternoon and read the other service chap not the original one all the answers to my enquire on the forem. My wife has an appointment wed morning to have the smoke test done? He wanted to know why it had not been done defore as this will be our 3rd visit since Sept! How am I to know why they diden't do it???? We will see what happens and I will get back to you Guy's. Am I glad it's under warrenty. Ron G K |
Well???it's fixed HA HA
scan P0456 small leak detected. Presurise system, Drop Tank, Block Vent no leak present. Replace purge solenoid as NVLD switch was allready done put tank back up erase codes. Well that's a lot of work to get rid of the check engine light. The Sercice Manager is still hoping this is the fix. If it comes on again they will stay with it till it is fixed? Thank God For warrenty for now. Any other suggestions?? We had a 2000 PT sedan and had no trouble with the darn light. What year did the trouble start Thx Guy's Ron G K |
| "Check Engine" idiot light on AGAIN | tezz | General Turbo Discussions | 15 | 23 Jul 2010 06:09 am |
| Check engine light, skipping | ab1 | Tech & Performance Forum | 2 | 02 Aug 2008 11:13 pm |
| 06 turbo check engine light | 06SilverTurbo | Tech & Performance Forum | 23 | 21 May 2008 02:20 pm |
| Faulty Check engine light? | Mel K | General Turbo Discussions | 5 | 23 Mar 2007 10:06 am |
| Check engine oil light question | AaronR | General PT Cruiser Discussions | 5 | 28 Aug 2004 03:18 am |
