2001 pt cruise control problems
Old 11 Nov 2008, 12:52 pm
charlieborg's Avatar
Send a message via Yahoo to charlieborg
Default 2001 pt cruise control problems
Hey guys. My pt has been acting up lately. Some times the cruise will work, then some times it wont. When it does not the cruise light stays on and if I try to set it it will go out after a few seconds to a min. Vacuum seems ok at the throttle body thing. What can I check next?
Old 11 Nov 2008, 02:16 pm
ucantcme's Avatar
Send a message via AIM to ucantcme Send a message via MSN to ucantcme Send a message via Skype™ to ucantcme
Default Re: 2001 pt cruise control problems
Moved to General PT Section.
My Baby:
01' Taupe Limited PT Cruiser w/ rear spoiler, Drop in K&N Air Filter, Limo tint all around, blue neon interior, blue LED windshield nozzles,
In-dash CD/DVD/Radio made by Jensen, Vent Visors, Chrome Antenna Bezel, Chrome Grille inserts, Dual Catback Exhaust, Scan Gauge II,
back-up camera, and a system containing 2 Lanzar 15" subwoofers and an MA Audio 1800watt amplifier.
Check me out on Car Domain!
Old 11 Nov 2008, 02:35 pm
From the Haynes manual:
The system consists of the PCM, Vacuum servo, brake switch, control switches and vehicle speed sensor. Some features of the system require special testers and diagnostic procedures.
checking:
fuses, brake light voltage (voltage from the brake light switch deactivates the cruise control), Visually inspect the control cable between the servo and the throttle linkage for free movement, vehicle speed sensor (dealer tested).
Old 23 Nov 2008, 10:08 pm
Send a message via MSN to saldagus
I had the exact same problem. Unbolt the vacuum servo (it's on the rear passenger side of the engine bay), underneath there is a connector. Either it has come loose or it's corroded. Mine was loose, been working fine since. Hope this works
Old 23 Nov 2008, 11:14 pm
hey thanks, I will check it out. Starting to get irritated with it! http://www.ptcruiserlinks.com/forum/...milies/mad.gif
Check Engine Light came on - code 1188? coolvirus General Turbo Discussions 38 25 May 2011 09:01 am
obd-II codes Punch General Turbo Discussions 13 06 Jul 2009 06:54 pm
cruise control problems charlieborg General PT Cruiser Discussions 3 18 Jul 2008 12:24 pm
