Back Up lights come on in drive 2003 PT
Old 22 Nov 2008, 10:32 am
Default Back Up lights come on in drive 2003 PT
I have a 2003 PT Cruiser and the back up lights are coming on when I am in drive. I can make them go off by wiggling the shifter (I have an automatic) but they still seem to come on when at a stop light. Anyone have suggestions on how I can fix this?
Thank you
Old 22 Nov 2008, 01:56 pm
damilleniumboy's Avatar
Default Re: Back Up lights come on in drive 2003 PT
Did you spill anything on the shifter? it's sounds like it's making a bad contact and sticking after you go through reverse gear.
1999 Corvette and it's mate a 2001 PT Cruiser Limited.
I'm not hard to please.............
..........I just like things my way
Old 22 Nov 2008, 02:35 pm
I don't believe so.
Old 22 Nov 2008, 03:20 pm
I did a search but all I found is an owner with a manual trans PT with the same problem.....
We have a 2002 TE PT with 27.5k miles and manual transmission. The other day, during a long run at a steady 60-65mph, my wife, who was in the car behind me, reported that my backup lights lit up on a couple of occasions, staying on for a few minutes at a time. I had no lights on, was not using the wipers, was steady in 5th gear, rarely used the turn signals or brakes, and I don't drive with my hand on the shifter. She could deduce no observable correlation (lane changes, braking, etc) with these occurrences. No codes were detected with either self-test (except the FL005, EE05, BL01 which you, rightly I think, correlate with internal software data). No new wiring or tampering on my part to account for it. Any ideas would be appreciated? - David, from Delaware.
The 2.4L with manual transmission goes through a back-up lamp switch that ties 12V power to the lamps. There is no other way for the lamps to get power. It must be a defective switch, or defective switch activation lever inside the transmission. Reference pages 8W-51-2 & 3 of the 2002 SM.
Follow up from owner - Yes, it was the switch. Good call. You are a lot better than I am at making sense out of those wiring diagrams.
2006 Touring, No Brake Lights cosmotcat Tech & Performance Forum 3 26 Sep 2008 07:19 pm
Problem with fog lights TaylorMade General PT Cruiser Discussions 6 13 May 2004 07:41 am
DIMMING LIGHTS AND PCM'S 1SPRINKLERMAN General PT Cruiser Discussions 9 26 Jan 2004 10:04 pm
APC Next Generation Tail Lights Jeff V Exterior Accessories Forum 10 21 Mar 2003 01:17 am
