Flashing/Flickering lights
Old 23 Nov 2008, 07:17 pm
Default Flashing/Flickering lights
So, for quite a while I had the typical issue of the lights flickering if you were to push the window button up when the windows were all the way up or if you hit the brakes. No big deal, it was annoying but not that annoying.
However, now I have the wonderful "hey, we're going to flicker all the time, interior lights and headlights" problem. It's quite a headache to drive my car at night. Of course, I took it to the dealer and they "couldn't reproduce it" (because they did it during the day, I bet) so no luck there.
It's a 2003 PT Cruiser Turbo with about 85k miles on it. I had the battery replaced earlier this year and the problem seems to have gotten worse after that, however, before the replacing of the battery it was still going on.
I've heard things about hypergrounding and replacing the multifunction switch.. given the fact that I'm not all that good when it comes to stuff like that, I'm wondering is it easy enough to do or should I just find a local place to take it to and ask them to do it.
I really, really can't stand to drive the car at night as a result of this.. and thanks to DST it gets dark at 5:30 now.
Old 23 Nov 2008, 07:30 pm
Default Re: Flashing/Flickering lights
Hyper-grounding might not work but it's pretty cheap and easy to do. A lot of did it a few years ago during a craze.
You can buy a kit for about $10 on eBay (like I did) and it starts with a ring from the ground at the battery and goes to all different points in the engine bay.
I went to a ground on the body of the car itself, another to the computer grounding point and a third to a grounding point on the engine block. You can just see all the extra wires, that I covered in chrome, going to the different places in the engine bay.
Old 25 Nov 2008, 05:27 am
SRG SRG is offline
First thing you should do, is have the battery terminals cleaned and take apart the ground terminal on the car body and clean that too.
Between my wife & I, we've owned 4 PT's over 6 years, and still currently own an 07. As long as the battery terminals were kept clean, the system ground that the car came with is fine.
If that doesn't fix it, then it might be the multifunction switch, (actually, I've ran into more MFS problems then dirty ground problems). One way I could tell my MFS was gone was the foglights would go on and off whenever they felt like it, even with the car off and parked! Try just tapping the end of the stalk lightly with you finger.
There are some good threads on MFS replacement here, just do a forum search if you need to change it.
Hope this helps;
srg
Old 25 Nov 2008, 03:42 pm
Hope this helps;
srg
Thanks.. I'm thinking its more likely a ground issue because I havent seen any weird behavior such as the fog lights or other things reported.. just the interior/exterior lights flashing.
I know the dealer did clean the battery terminal connections, but I doubt they did anything with the ground terminal. I guess that'll be the first thing I try.
Old 25 Nov 2008, 10:19 pm
SRG SRG is offline
Could be bad cables as well, I say "cables" because even if it is just the ground cable, the battery cables are part of a single harness, (I think around $70-80 at the dealers).
On my wife's 03 touring, it was the starter cable, so once in a while she went to start the car, it was D.O.A., except the interior lights worked, chimes, etc. Started out once in a great while it happened, then as the conductor got worse, it happened more and more.
You could have the same thing only on the ground cable. You could have someone check the cable with a continuity tester, while you flex (vibrate) the cable a bit.
Replacing the cable harness is like a 15min job, 20 if you take your time.
Let us know how you make out.
srg
PT Cruiser 1959 Cadillac tail lights available Marge Classifieds: For Sale/Trade 4 23 Oct 2009 02:31 pm
2006 Touring, No Brake Lights cosmotcat Tech & Performance Forum 3 26 Sep 2008 07:19 pm
Tail Lights you've seen? PTmodrod Exterior Accessories Forum 2 13 Jan 2008 09:24 am
LIghts, Lights, Lights King_Rob Classifieds: For Sale/Trade 4 20 May 2005 09:14 pm
APC Next Generation Tail Lights Jeff V Exterior Accessories Forum 10 21 Mar 2003 01:17 am
