2 Issues - Need Help
Old 09 Dec 2008, 11:25 am
07PTSilver's Avatar
Default 2 Issues - Need Help
#1 --- For some reason or another, I keep blowing fuses when I use my air compressor for roadside tire changes. The compressor is a 15A and the fuse that keeps blowing is a 15A in the power outlet slot. I've already blown through 4 fuses doing 2 tire changes today.
#2 --- Letting the car idle, the rpm's once every couple of minutes dips down and the car shakes and the a/c blows hot air. I'm guessing this is happening when the a/c compressor kicks on. When I'm driving, at any speed, all is good, ice cold air, no problem. This just happens inbetween calls, sitting in a parking lot idling. Any ideas why this might be happening? No check engine lights or anything like that.
2007 PT
Old 09 Dec 2008, 01:02 pm
crusierdad76's Avatar
Default Re: 2 Issues - Need Help
Ok I'm not 100% sure but Id say the 15 amp fuse should be up to a 20 amp the compressor is probably pulling a tad more than the 15 and it kicks the breaker/fuse
on the rpm thing i think some body else had that issue don't remember what it was some map sensor or something like that
Old 09 Dec 2008, 03:45 pm
There is a sensor somewhere that tells the computer that the compressor kicks on, the computer is supposed to react to that by raising the idle to compensate. Here's something to read....
Trouble Shooter | Motor | Find Articles at BNET
Idle Issues CoryMartelca Tech & Performance Forum 2 23 Oct 2007 07:04 am
Magnaflow clearance issues? tezz Turbo Performance 6 20 Feb 2004 09:42 pm
Any long term issues Mike Radowski Stage Turbo Kits 8 20 Feb 2004 08:28 pm
weight issues? Punch General Turbo Discussions 7 01 Jan 2004 09:38 pm
Suspension Issues seanyboy Tech & Performance Forum 3 14 Jan 2002 02:08 am
