Remote Keyless Entry
Old 25 Dec 2008, 01:48 am
Question Remote Keyless Entry
Just brought home a 2006 PT and it didn't come with an owner's manual. I was hoping someone out there might be able and willing to tell me how I can determine if the car is equipped with a keyless remote entry receiver? I would like to get a remote entry key or fob, but would hate finding out later that it wouldn't work with my model.
Thanks very much.
Old 25 Dec 2008, 05:02 am
lomara's Avatar
Default Re: Remote Keyless Entry
Hi jcmoran,
You can either order or download an owner's manual directly from the Chrysler website. Starting on page 24 of the manual is the section about the remote function on the keys for vehicles equipped with keyless entry.
My Chrysler: Chrysler Owners Service Manuals - Chrysler Cars, Minivans, SUVs, Convertibles, Crossovers
According to the manual, the keyless entry keyfob is programmed at the factory, so I would think a Chrysler or Dodge dealership would be able to look up your PT's VIN and determine whether or not your vehicle was equipped with this. I don't know that much about the PT other than what I've learned by reading these forums. (I've had my 2006 PT since July 2008.) I do know the dealers can make new keys based on the VIN number of your vehicle. The keys are embedded with chips, so if you lose a key, and have a plain key cut from a locksmith, it will not start the car but it will open the doors. The Dodge dealership parts dept. manager told me this when I asked about having extra spare keys cut. ($50 for the special key and $50 to program the chip in its base.) You will need to go to the dealer and give him the VIN and he'll have to cut the key and program the chip in the replacement key base before it will start the car.
Hit up your local dealership and see what they can find out for you.
Good luck and enjoy your PT.
Boredom is for the uninventive.
2006 Cool Vanilla PT Cruiser
Old 25 Dec 2008, 09:36 pm
soonercruiser's Avatar
Cool Re: Remote Keyless Entry
What does the key fob look like?
Or did you only get a "key", with no buttons on the fob?
(I'm thinking that the remote keyless entry came with even the base model; which the soonercruiser even was. If the car was used, the previous owners may have misplaced the key fobs.)
If it does have a key fob for remote entry, it's only a matter of a new battery and programming the key.)
Frank, aka SOONERCRUISER,
Old 25 Dec 2008, 11:38 pm
Yeah, I only got a key, but I did download the owners manual from Chrysler and based on that, I believe I do have some form of security system, because when I turn the key on, I get a full array of lights on the bottom of the speedo going through their self-tests, and one of those is the security indicator light.
I need to make an appointment with a dealer to have the rear quarter panel windows taken care of, as that was a safety recall item. I will take advantage of that time to find out for sure if a set of remote key fobs are doable.
Thanks very much for the input.
Old 26 Dec 2008, 01:00 am
lomara's Avatar
That's interesting to hear, soonercruiser, as I have a 2006 base PT and got no keyfob with my keys. I got two keys and both are regular keys with the plastic bases without buttons. I don't think the remote entry was standard on the base model, but then again, I'm new to PT's, and I bought mine used. When I start my PT, I get the cluster self-test lamps and there is no security symbol illuminated during the test that I can see. (Unless the solid dot is for the alarm? It doesn't flash when I start the car as stated in the manual if it were equipped.)
Old 26 Dec 2008, 12:08 pm
HEY JC!
A reminder that if the dealer says it can be done...only get a quote, and look on e-Bay for key fobs. You can probably save a hundred dollars or so that way!
remote keyless entry 03 PT Cruiser Turbo tke4147 Sound and Security Forum 1 04 Aug 2008 09:25 am
remote keyless entry programming Ray70077 General PT Cruiser Discussions 2 09 Apr 2008 11:20 pm
Remote keyless entry and exterior lights circuit f Nawalins Tech & Performance Forum 3 01 Sep 2004 11:44 pm
Exterior lights and remote keyless entry Nawalins General PT Cruiser Discussions 1 30 Aug 2004 07:33 am
Keyless entry? Blade General PT Cruiser Discussions 13 22 Mar 2004 05:52 pm
