ABS and Traction control warning lights on
Old 07 Jan 2009, 03:37 pm
Default ABS and Traction control warning lights on
Help. Ive a 2001 automatic limited cruiser and the amber ABS light and amber traction control are on all the time and the hand brake warning light comes on, often, whilst driving. Is my only option taking it to a garage miles away to put on a diagnostic computer ?
Old 07 Jan 2009, 04:57 pm
Default Re: ABS and Traction control warning lights on
have you tried looking for any kind of code the computer might be storing?
Old 07 Jan 2009, 05:06 pm
have you tried looking for any kind of code the computer might be storing? All 3 lights indicate you have something wrong with the braking system. Were you in any kind of crash? Is the brake fluid container filled to the proper level? Any sings of fluid leak from the braking system at the wheels?
Old 07 Jan 2009, 05:22 pm
Thanks for the reply. I will check the brake fluid in the morning (Im in England, freezing and dark)
How do I check for codes ?
Old 07 Jan 2009, 05:32 pm
Put the key in the ignition and without actually starting the car, turn the key forward, then back. Do this 3 times within 5 seconds and the 3rd time keep the key pointing towards the windshield. if there's a code stored in the computer it will show up in the center dial, example: P0700 and if there's no codes stored it will say "done".
Also, if you haven't done, take a look at a great U.K. site that has loads of members willing to help out with questions. You don't have to join but some of the forum won't be accessible if you don't.
UK Cruiser Club :: Index
Old 08 Jan 2009, 03:59 pm
Thanks again for the help and info. I checked the brake fluid, its a bit down but nothing major. I checked for codes and there were none stored. Ive got a guy coming round tomorrow to hook it up to a computer to hopefully tell me why the lights are on- lets see if that works, when I find out ill let you know the result. All the best.
Old 09 Jan 2009, 02:57 pm
Crewzin, the diagnostic says Ive got a broken front left sensor which is effecting the ABS, the Traction off and maybe the handbrake light but that might be something else. Ill find out Monday how much that will cost with labour, sounds like its a pretty easy job but as Cruisers arent that common in my part of the world, Im sure they will charge top amount for the part. Well see.
Old 09 Jan 2009, 03:59 pm
..and your part of the world is:....?
Old 12 Jan 2009, 09:12 pm
There are sensors by each wheel - they seem to be sensitive to moisture - my lights TRAC & ABS come on in rain/snow - just when you need them
If wet for several days, brake light comes on, too. When it all drys out, lights go out.
Old 14 Jan 2009, 11:52 am
Hmmm....I have been having a similar problem. The ABS and TC/OFF light combination has been on in my PT for a day or so. It won't stay on consistently though. The weather has been junk lately with lots of rain and cold weather.
If wonder if its the same problem. I tried to get a trouble code, but it just came back with Done.
